Excellent Autoline Afterhours
Discussion in 'EV (Electric Vehicle) Discussion' started by bwilson4web, Jun 29, 2023.
  1. bwilson4web
    15,513
    49,392
    on paper it looks good, but in real life, i'm more concerned about out of warranty premature failure.
    Merkey likes this.
  3. bwilson4web
    15,513
    At 111,720 miles, my Tesla is long since beyond the warranty which makes me happy. I can do anything I want and not risk losing the nonexistent warranty. For example, the after market wheels:
    So after reading: The Effects of Wheel Design on the Aerodynamic Drag of Passenger Vehicles
    Approximately 25 % of a passenger vehicle’s aerodynamic drag comes directly or indirectly from its wheels, indicating that the rim geometry is highly relevant for increasing the vehicle’s overall energy efficiency. An extensive experimental study is presented where a parametric model of the rim design was developed, and statistical methods were employed to isolate the aerodynamic effects of certain geometric rim parameters. In addition to wind tunnel force measurements, this study employed the flowfield measurement techniques of wake surveys, wheelhouse pressure measurements, and base pressure measurements to investigate and explain the most important parameters’ effects on the flowfield.
    So I'm making my own wheel covers based on the paper. Here is the prototype:
    I'm working on the fittings to attach to the wheel.
    #3 bwilson4web, Jun 30, 2023
  4. mikefocke
    3,692
    1,644
    Sanford, NC
    I remember some similar in the '50s. My only concern would be the brake cooling and wheel bearing cooling effect. Wonder if anyone ever measured that.
    It would seem you need to be an SAE member to review the complete paper.
  5. bisco
    49,392
    i will be more comfortable when there are more repair shops that can fix any ev. however, it is looking like if the government has its way, it will be dealer only for most all cars.
  6. bwilson4web
    15,513
    I will but more as part of hunting down inefficiencies. For example, even though the vast majority of kinetic energy is captured by regenerative braking, there is a small part at very low speed that adds heat to the brake pads. A zone where typically there is very little airflow and not one I'm worried about. Regardless, it is fairly easy to add venting to the solid wheel cover. I am more concerned that blocked off, the pressure differential will 'blow the covers off' at speed.
    There is normal 'resting' of the brake pads against the rotors. A fine anti-corrosion strategy, it is also a small drag force that can be reduced or even eliminated. Benchmarking will let us know how much.
    Recently, it looks like turning the head lights off during the day may have a measurable effect on efficiency. I have not benchmarked it, yet.
    I also plan to trim down a water noodle and with duct tape, reduce the area and shape of the air inlet. Again, it will be benchmarked along with measuring coolant temperature.
    The outside mirrors are also on my list to be investigated.
  7. Trollbait
    11,511
    I suspect heat only becomes an issue with driving conditions beyond what is legal on a public road. Steel wheels are also more closed to air flow, and cooling doesn't seem to be an issue with them. Besides, brakes aren't heating up when most of the brake force comes from the motor.
    In some recent car models, the manufacturers have been incorporating a spring system in the pad clips to push them away from the rotor surface to eliminate that drag.
    bwilson4web likes this.
