Excess Oil Consumption in the 3rd Gen Prius?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by nekoashide, Sep 2, 2013.
  1. nekoashide
    nekoashide Junior Member
    25
    US
    I just traded in a 2010 Ford Focus with 134k miles that i bought new and it never burned a drop of oil with 7500mi oil changes at the dealership. (Motorcraft 5w20 and Motorcraft Filters) I want to believe that the Prius can do 10k Oil Changes with 0w20 Toyota Oil and Filters but i keep hearing about excess oil consumption on the older Prius's.
    Was this fixed in the 3rd Gen Prius or later and is it an issue now? I do a lot of driving and i always let the dealership perform the maintenance per the book, I'm a little worried because i just want to drive it and not have to worry about checking the oil every week because it's burning through a quart. Right now the oil looks new and it has 23k on the engine and 3k on this oil change with no usage. Should i worry?
  2. orenji
    orenji Senior Member
    5,884
    3,486
    Prius motors don't seem to have an issue with burning oil, but any engine could burn oil, Its best to check your oil at every fill.
    Montgomery likes this.
    49,378
    not sure what you keep hearing, but i have seen very few reports here about oil consumption. i'm on my third pri and have never seen the oil level change at all.
  4. nekoashide
    25
    US
    From around the Internet, Google searches and other Prius from forum searches. To me oil consumption is abnormal on a properly maintained vehicle but TSB T-SB-0094-11 makes me worry that it was an issue with other Toyota's and the Prius has a similar engine design.
  5. orenji
    5,884
    3,486
    I have owned many Toys and have never had an issue with usage of oil. Just change the oil every 5K.
  6. wjtracy
    wjtracy Senior Member
    11,321
    3,590
    Northern VA (NoVA)
    I think the answer is you do NOT need to worry.
    The Prius is among the top cars for reliabilty and this includes minimal oil losses.
    You need to be aware that automotive web site posts are biased toward those motorists reporting problems, because if you are not having problems, no sense posting about it.
    Except for EV's , no ICE car I am aware of can promise zero oil losses forever.
    For this reason the poster above mentioned the best practice is check oil every fill-up for every car (nothing special about Prius, just any ICE car could lose oil suddenly). Like many best practices, I actually don't do it myself. My 2006 holding tight at 125K maybe a hint of low level once recently, bumping up monitoring a little bit.
    Merkey likes this.
  7. RRxing
    RRxing Senior Member
    2,519
    1,790
    NEPA
    I have never had any noticeable loss of oil between oil changes, but I still check it every week or so.
    Merkey likes this.
  8. ETC(SS)
    6,542
    Don't believe everything you read on the internet...ESPECIALLY from know-it-all jerks (sometimes....like me!) that think that they know more than they really do.
    And NO.
    You shouldn't worry.
    Prius owners are already famous for that and you don't want to waste time fretting over things that you don't have any rudder input over, especially since you already have the car!
    If you bought your G3 new, and take good care of it, then I don't think that oil consumption is going to be a problem for you especially f you trade it in early (at 140k) like you did with the Focus.
    I'd like to tell you that I'm anal enough to check my oil every time I fill the tank (500 miles) but it's closer to every two tanks.
    50K miles on a 2010 and zero consumption.
    I've got three years and a few thousand posts on this site and I don't hear about much about oil consumption with the G2s or G3s.
    Since you're letting the dealership swing the wrenches on your car, I think I'd put the giveacrap switch in the "don't" position.
  9. Britprius
    Britprius Senior Member
    5,194
    1,914
    Herefordshire England
    I have a gen2 Prius now at close to 100,000 miles and no measurable oil use between 10,000 mile oil change intervals. This does not mean I neglect to check the oil level as that is a asking for trouble.
    Can you be that sure the person that changed your oil torqued up the drain plug, changed the washer, seated the oil filter gasket correctly?
    Any of these can give a slow leak and if you do not check how are you going to know. Surely you top up the windscreen washers sometimes visually check brake fluid level and air up your tyres why not check the oil level while your there.
    Checking these things is part of driving, and in the UK showing you know how to do this is part of our driving test.
    John (Britprius)
    Merkey likes this.
  10. Former Member 68813
    3,524
    981
    US
    That specific issue is for 2.4L engine that had defective pistons installed (too few oil holes). Similar to the 1.8L engine problems a decade ago. The engines in the current and previous prius are not generally known for excessive oil consumption, but it's always possible, thus check your oil.
  11. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I have 23.5k miles thus far on my Prius. I haven't noticed any abnormal oil consumption. I haven't heard anything special about Prius consuming oil. As with any vehicle, hybrid or not, some individual cars may consume oil and some may not. Prius is not immune to or especially susceptible to oil consumption to my knowledge.
  12. Bill Norton
    Bill Norton Senior Member
    1,834
    601
    MONW, Ks.
    You should worry.
    If that's what it takes for you to pop the hood once in awhile.
    It's really not that hard. You can do it without soiling your hands, Big Guy!!
    Oil consumption can be related to usage. On a long, high speed (+80mph ) trip with two bikes on a trailer hitch bike rack I saw oil consumption. It was like having airplane speed brakes deployed,,, 35.8 MPG into a headwind in hilly western PA. My worst EVER....
    This car used as a normal daily commuter did not seem to consume much between 10k oil changes and is always in the mid to upper 40's mpg.
    Edit: That oil consumption was ~2800 miles/qt.
    But that was all in 5 days of HIGH Speed travel a with weight and aero load on the car.
    When used the car in a daily manner it was maybe down a qt. by 7500 miles.
    Always M1 .
  13. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    My dipstick goes from full to half around 7k miles, then I add 1qt of regular 5w30 oil which seems to slow the burning process, then I change the oil at 8500 miles
  14. Mendel Leisk
    38,648
    Oh definitely: who knows how long that might last, LOL.
    Seriously, ours is the first car we've had that consumes no oil between changes, albeit the 8000 km Canadian interval. I guess it will vary, depending on manufacturing tolerances etc, but so far...
    And I can't see a correlation between oil consumption and needing to go to shorter change interval; with an engine that consumes oil fast enough you never need to do an oil change.
    Merkey likes this.
  15. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
    There have been a couple reports of cars burning oil at higher mileage, and I believe I posted a thread with some links at some point.
    There are definitely a lot of members here who continue to make high-level statements concerning Prius reliability, and completely refuse to acknowledge the existence of any issues.
    With that said, it's too early to say that the Prius is/ will be a chronic oil burner, so I would not worry about the issue.
    iPhone ? - now Free
    m.wynn likes this.
  16. Bremaria
    Bremaria New Member
    Austin, Texas
    I have a 2011 Prius III and it started burning oil around 90k miles. It goes through just under a quart every 1200 miles. I can't go the 10,000 interval between oil changes w/o adding oil. The dealer can do a oil consumption test where they:
    -Dealership tops off your oil and puts anti-tampering goo on oil cap, dipstick
    -You drive for 1100 to 1299 miles
    -Return to dealer, they add 1 quart of oil to car
    -If the dipstick shows anything lower than "full", it is consuming excess oil
    I've had this done twice and it just barely passes this excess consumption test so they won't do anything. Chimicles & Tikellis LLP law firm has begun a class action investigation for 2010 and 2011 Prius's. Just google "Chimicles & Tikellis Prius class action" and it will be a few results down.
    If you are having this issue, you can call Toyota headquarters to complain at: 1-800-331-4331 from 7am to 7pm CST.
    FYI, for another oil consumption class action against Toyota (certain models/years of Camry, Solara, Corolla, Matrix, Rav4 and Scions) , they extended the power-train warranty to 150,000 miles and 10 years.
    This is my first Toyota and I am not pleased with the performance. I have never owned a vehicle where I had to top off the oil between oil changes. I can't believe they say it is OK to consume up to a quart every 1200 miles. The interval for oil changes is 10,000 miles. The Prius holds 4.2 quarts of oil. If you lose 1 quart every 1200 miles, you would run dry in just over 5000 miles!
    At that rate of loss, you would need to add over 8 quarts of oil for every oil change interval. At $5-10 per quart for synthetic oil (as recommended by Toyota), that would cost $40-80 per oil change interval to replace the consumed oil.
    I didn't buy a Prius for it's curb appeal; I bought it for how "green" it was. I'll keep repeating the oil consumption test until it qualifies. If it does, Toyota may authorize full or partial payment for repairs. If anyone has success in getting their Prius fixed, please contact me.
  17. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Drive it fast on the freeway for extended periods of times. That's where is will use the most oil. Best of luck to you. Sorry to hear that your vehicle is using oil. I can't stand when a vehicle eats oil. It just shouldn't happen in this day and age.
  18. Mendel Leisk
    38,648
    The owner's manual sets "excessive" oil consumption at a quart every 600 miles, IIRC. The test parameters mentioned above have double the distance factor. Maybe Toyota is making some concessions behind the scenes?
    FWIW all our Honda's, over decades, had some consumption, but never more than a pint between oil changes. Maybe there's some sort of benefit, to minor but steady consumption??
    Raytheeagle likes this.
  19. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    I've actually that minor steady oil consumption is the best over the long run, that would make sense with all those honda engines
  20. Mendel Leisk
    38,648
    Yeah, they're like two-stroke engines, purposely consuming oil. :)
