Excessive condensation in 2016 , not getting better
Discussion in 'Gen 4 Prius Technical Discussion' started by Biscuitman, Mar 17, 2022.
  1. Biscuitman
    Biscuitman Junior Member
    Ottawa
    Technology
    First time poster!
    2016 technology model with sunroof.
    Our vehicle has had the headliner repaired under the tsb bulletin in 2020 and the problem persists with the windows fogging up whenever below 0 c.
    No water on mats
    We are not recirculating the air.
    We have used silicon gel bags to no avail.
    Any suggestions?
    Thanks
    49,521
    welcome!
    are you bringing anything wet or frozen into the car? one guy said skis were a problem
    Biscuitman likes this.
  3. Biscuitman
    Ottawa
    Technology
    Nope, nothing wet.
    Thanks for the welcome!
    #3 Biscuitman, Mar 17, 2022
  4. Hidyho
    Hidyho Senior Member
    2,698
    529
    2018 Prius
  5. Biscuitman
    Ottawa
    Technology
    Thanks very much, I will definitely bring this up with the new dealer I am taking it to this week.
    My wife suggested she thought the circulation may be the issue and this seems to cover this.
  6. Tideland Prius
    16,159
    Have you checked the air filter? Maybe the filter is clogged so there’s not enough air flow. It’s behind the glovebox.
  7. Biscuitman
    Ottawa
    Technology
    No I have not, will check that , thanks.
  8. Nico3d3
    Nico3d3 Junior Member
    34
    Quebec
    Fog on windshield has always been a problem on all my cars, during the winter. I try to keep the cabin dry but, it's almost impossible to not have at least a small amount of snow on floor mats. Fortunately, I found a small trick to reduce the amount of fog. You have to keep the windows clean. I wash them with Invisible Glass every 3-4 weeks. It make sense, condensation need a sticky surface to cling to. A clean and smooth window doesn't provide a good enough surface for it to stick.
    #8 Nico3d3, Mar 17, 2022
    bisco and Biscuitman like this.
  9. Biscuitman
    Ottawa
    Technology
    Interesting, I will try the window clean technique also, thanks.
    I have owned multiple cars and have never had the amount of condensation that this car has, there is something seriously wrong and I am thinking it has to do with the sunroof that as I understand it is not common in the Prius. When we bought it this version with the sunroof , heated seats , etc was only available to dealers in Toronto, Montreal and Vancouver in Canada in 2016.
    We live in Ottawa so bought from a Toronto dealer.
  10. vvillovv
    vvillovv Senior Member
    3,689
    1,303
    NY
    I read here at PC about a year ago that Power Mode doesn't cycle the heat. I've switched to Power Mode whenever I run the heater and I haven't had nearly as much fogging and the frost on the lower windshield from using the Primes heat pump to heat the car in EV mode and than after sitting all night - is gone completely. I'm not sure that is going to make much sense unless you've seen frost on the bottom of the windshield inside just above the defroster outlets in your Prius..
  11. Biscuitman
    Ottawa
    Technology
    Will try that and see if it makes a difference for us. it has become much milder in the last day so probably won’t have any condensation now until fall kicks in.
    vvillovv likes this.
  12. Biscuitman
    Ottawa
    Technology
    Update :
    Dealer has told me that the pump that is supposed to bring fresh air in was broken so the inside air was constantly recirculating .
    This he feels is the main cause of the condensation.
    Ordered a new pump and it will be installed .
    He also noted that the sun roof was not sitting perfectly flush and allowing “more water to enter” then the norm.
    This will be adjusted also.
    Thanks for the all the helpful suggestions, it was useful .
    Tideland Prius, vvillovv and PaulDM like this.
