Excessive crankcase pressure
Discussion in 'Gen 3 Prius Technical Discussion' started by donzoh1, Apr 27, 2024.
  1. donzoh1
    donzoh1 Active Member
    440
    151
    Lenexa, KS
    My 2013 has excessive crankcase pressure. It runs fine with and has no trouble codes. As Taylor Swift might say, "the ICE has been through it" and eventually will probably be replaced with a JDM motor. Meanwhile, is there a way to tell whether the excess pressure is from piston ring/cylinder wall bypass? I was thinking maybe a half an ounce of oil in each cylinder could eliminate the symptom for a few seconds. Is it a good idea to vent excess pressure? I did install an oil catch can which I empty at each oil change. The engine doesn't burn much oil.
  2. Danno5060
    Danno5060 Member
    197
    82
    Wyoming
    The PCV system should have a slight vacuum in the crankcase. If it has pressure, but it's not the rings, change the PCV valve, and check out the vent lines.
    PriusCamper likes this.
  3. PriusCamper
    PriusCamper Senior Member
    11,071
    4,507
    Pacific Northwest, USA
    I'm always telling people that replacing a PCV valve is a waste of time and concerns about its failing is a throw back to a 1/2 century ago when engines ran way dirtier.
    However... With your symptoms, replacing the PCV would be the first thing I'd consider.
  4. donzoh1
    440
    151
    Lenexa, KS
    My deepest apologies to anyone who was inconvenienced or traumatized by any thread duplication. I don't recall bringing this issue up before.
    Anyway, PriusCamper, thanks for your response. When I did the head gasket (after the dreaded EGR Cooler thing) I noticed some cylinder wear which I was blaming for the excess pressure. I did clean the cooler and the EGR Valve and verified the ball did rattle in the valve but maybe should have just replaced it.
