Excessive Noise (wind) Battery Fan
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Stringbeanie, Jun 6, 2011.
  1. Stringbeanie
    Stringbeanie New Member
    Southern California
    Hi Fellow Prius Owners. I am wondering how much fan noise is normal from the passenger rear vent while driving. My fan is on almost constantly and it sounds like wind coming in through the rear window but it is actually the fan from the vent. I have had passengers in the front seat ask what the noise is coming from the rear. I have taken it in to the dealer 3 times and they say that is normal for Prius' to have that noise all the time. My Prius is 2011, bought on Feb 2, 11. I have 5000 miles and the noise has been present from the onset of owning the vehicle. I am really frustrated because it sounds excessive to me. Is your fan on most of the time and significantly audible?
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Nope, mine is loud at times and not loud at others. If it is very hot out or I'm using the pack alot in electric and it gets hot then it comes on and yes it can get loud. Most of the time though, I hve the radio on which makes it nearly impossible to hear.
    If yours is on constant t full speed I would say there is a problem. If it does change in pitch, then the fan is changing speed based on temperature an it is functioning normal. Is your rear vent blocked in any way?
  3. k9frog
    k9frog New Member
    88
    sullivan co ny
    not sure how this will help ya, we have an 2011 prius and we had it now for 6 weeks so far i cant say i even heard it ,just asked the wife and she hasnt noticed it either,
  4. Gurple42
    Gurple42 New Member
    354
    Santa Monica, Ca.
    I too have had an 2011 Prius for 3 months and have never been aware that the fan is on, I'm sure it has been on but I've not noticed it. Good Luck!
  5. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    I have seen a few people talk about this. Yesterday it was 96 here i drove about 5 miles. Then i parked the car and left it on with the ac running full blast. i got in the back seat and put my ear right up to the vent. I coundn't hear anything and couldn't feel any air flow with my hand. I let it sit long enough to drain the battery most of the way down. i have never heard the fan in my 41,000 miles with the car. I do keep it cool inside the car in hot weather around 70 degres.
  6. Stringbeanie
    Southern California
    Thanks for all the replies. Last night, I drove 25 miles with the outside temperature at 60F and after the first 2 miles, the fan was on constantly when the speed was over 35 mph. It's not on while idling. The battery indicator is almost always at the top (except after prolonged parking). I'm not sure if that is normal. My local Toyota dealer is basically telling me that it's normal and I have to put up with it. Do I have any other recourse?
  7. tonyrenier
    tonyrenier I grew up, but it's still red!
    362
    44
    Green Bay, WI
    I have a 2010 III. I have over 25K miles on it and have never, ever heard that fan. I'd bring it back to the dealer and if they're no help find another one or contact customer relations.
    Good Luck,
  8. dropshot
    dropshot New Member
    28
    I hear mine on occasion, usually when it's hot outside and in stop and go traffic.
  9. BrettS
    BrettS Active Member
    290
    136
    Orlando
    The fan should only come on when the battery temp is high... but this can depend on a lot of factors... outside temperature, inside temperature (because air for the battery comes from the inside of the car) and how much the battery is being used, among others. Additionally, I believe it's a variable speed fan, so it may be slower (and quieter) at times and faster (and louder) at other times. Because there are so many variables it's hard to compare what other people are seeing... particularly when they're in different climates.
    Now, what I would suggest doing is asking the dealer to test drive one of the 2011's on their lot... preferably during a hot day, so the fan is more likely to come on and see if the fan sounds the same as your fan. If it does, then it's likely that the noise is normal and you'll just need to live with it. If not, then take the service manager for a trip in both cars and get him to see the difference.
    Also, one more point... I'm in Orlando where it tends to be reasonably warm;) I rarely (if ever) hear my battery fan on the way in to work after the car has been sitting in a reasonably cool garage all night. However, I usually hear it during much of my commute home, after the car has been sitting in the hot sun all day. For some reason I usually don't notice the fan until 10 or 15 minutes into the commute. I'm not sure if that's because the AC fan is running at higher speeds duiring the beginning of the commute and it covers the noise of the battery fan or if the fan doesn't start immediately for some reason. Perhaps enough air is naturally forced through the battery vent when the AC fan is on high that it doesn't need to run it's own fan.
    OK... maybe two more points... I'm also a bit puzzled by your description of this as wind noise. When my vent fan is running it sounds more like a motor or a fan... not really what I would describe as wind noise. Maybe it's just a case of semantics, but if you're hearing more wind and less fan then maybe something is blocking the vent.
  10. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    +1. This is what I am thinking... perhaps the duct tube is squished or something is stuck deep inside. I figure the dealer didn't even look at it.
    Personally I would either take stuff apart myself and inspect it or I would sit at the dealer till they did and accompany them during the process.
  11. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    From the different replys that you got, I would say there is a problem on your car, the fan or the computer that controls the fan operation. Stay on the dealer, or another and try monitoring the temp thru a small hole in the fan exhaust (one which you can later plug) It seems to me the temp should always be less than ambient when 90 degrees plus. This could be very important down the line as your HV battery could fail, big time . So fix it while it is in warranty. You do run the Air Conditioner, right? More important for cooling the HV Battery than the passengers !
  12. Prius-it
    Prius-it Junior Member
    39
    Baltimore
    I've noticed my battery fan recently and I didn't notice it when it was only like 60-80 degrees outside. Currently it's like 95 degrees outside. It's noticeable but I wouldn't call it excess. More like a white noise aka whirling noise when you step on the brake and the battery charges, or when car runs only on battery.
  13. VoicesInMyHead
    VoicesInMyHead New Member
    52
    Georgia, US
    I have a 2011 Prius Two, and the fan comes on regularly and almost anytime the car is in motion more than 30mph... and turns off (or slows down, anyway) as the car comes to a stop. Seems to me it's just being proactive with the battery cooling.
  14. kaapie
    kaapie Junior Member
    Nashville
    I have 2, 2010 Prius, bought at the same time from same dealer. One is mine, one for my wife. My one , you hardly hear the fan. In her one, I hear the fan almost all the time and then I also hear a high pitched sound that sounds like the fan bearing :confused:
    I plan on going to the dealer next week to get them to take a look.
  15. BWATL
    BWATL Junior Member
    Atlanta
    Old thread bump. I've had my 2013 for about a month and never heard a sound from this vent, but starting today I hear it anytime the car is in motion. It was around 83 today, which isn't crazy hot, and it's still making the noise at night after it has cooled down considerably. It's very annoying. :(
  16. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    Have you checked for clogging of the duct? Even on hotter days, mine runs so slowly it's barely audible at close range, even with everything else off and no outside background noise.
  17. Okinawa
    Okinawa Senior Member
    1,333
    317
    I had a 2011 Prius. I drove it 48,000 miles. The vent fan was very quiet in it. I think you need to have someone take a look at it. It should not be loud.
  18. BWATL
    BWATL Junior Member
    Atlanta
    I'll check it tomorrow. This seems to directly correlate with the vehicle speed, which is odd for a fan. It sounds like the vent is open to the outside and it's definitely something that just started.
    Tina P. likes this.
  19. bisco
    49,371
    can you hear it when stopped? have someone sit in the back and give a listen while you drive.
  20. Mendel Leisk
    38,644
    Something not right. I've NEVER heard our hybrid battery fan. And this is knowing it IS running, even up to speed 4 (out of 5 or 6 I believe). If it is this fan, I wouldn't just get annoyed, I'd get alarmed, check it out.
