Excessive oil consumption solved by a Ford dealership
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mikeflores2000, Jun 15, 2018.
  1. mikeflores2000
    mikeflores2000 Junior Member
    52
    23
    Merced, CA
    Took my 3rd Generation Level 4 2010 Toyota Prius purchased new 07-14-2009 in for a Cash Offer inspection by Razarri Ford in Merced, CA. The Acquisition Manager was a former technician and discovered
    the oil filter had leak smears going back years. A past Toyota dealer replaced the internal paper filter
    but must have improperly installed the metal oil filter housing and rubber O-ring.
    2 years ago I reported excessive oil use / oil leak to NHSTA. In the past 6 months or 10,000 miles I've added only 1 quart not every 2000 miles as occurred 2 years ago.
    This leads me to believe that the Ford dealer may have discovered the root cause of losing quart of oil
    every 2,000 miles: a past Toyota dealer didn't seal the gasket when changing the oil!
    This time around after oil and filter were again changed and gasket lubricated the leak stopped.
    By the way per NHTSA, there are 2294 complaints logged against 2010 Toyota Prius.
    Compare this to the 40 complaints logged against 2010 Chevrolet Corvette.
    Preeeus and Starship16 like this.
  2. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    Why didn't Toyota just use a simple spin-on oil filter for the Prius engine!
  3. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Waste reduction. The cartridge is much easier to deal with (if desired, it completely burns to ash). It seems they may be going back to spin-on though. Too many monkeys holding wrenches tightening the housing too much. And I guess also not installing the "o" ring with grease! Every filter comes with a new "o" ring.
    4est likes this.
    52,692
    do all these nhtsa complaints help anyone, or are they toothless?
    paprius4030 likes this.
  5. Starship16
    1,348
    1,455
    Beach Christmas
    Somewhere out there, there has got to be some GOOD monkeys with wrenches. ;)
  6. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    This car was made to be environmentally friendly, it would be counter productive to have a metal oil filter that take up landfills, energy to compact, recycle or destroy the metal element.
    Starship16 likes this.
  7. orenji
    orenji Senior Member
    5,887
    3,488
    Would you not see the oil all over the car, if it were losing oil this way?
  8. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Title of this thread misleads, consumption is not the same as leaking.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    And to compare a Prius to a corvette(n).
    But I bet te ratio of Prii sold and corvettes sold equates to the same value(y).
    m.wynn, paprius4030 and Grit like this.
  10. Mendel Leisk
    42,185
    Proper positioning of the O-ring is problematic. Also, it's recommended to apply fresh oil to it. Couple that with installers using impact wrenches or whatever to spin it on, there's been more than a few instances: owners attempting their first DIY change and finding the the oil filter near-impossible to remove. Last but not least: it's possible to reinstall the cap without a filter. And what can be done, will be done...
    I like the concept, think they need to sharpen their pencils a bit though, on the application.
    Oh, and what's with that little metal tab? I've done about 15~16 oil changes, and can attest: that thing does NOTHING. Seriously, you forget it's even there. It's some fussbudget engineer's brainchild, and it really is innefective/useless. At least it doesn't impede anything.
    Sounds like me sometimes... :oops:
    RoadNoise, Starship16 and Raytheeagle like this.
  11. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Agree. Corvettes builds are built for speed and power so they are much more solid. And most of those owners are probably great DIYers so less complaints.
    Raytheeagle likes this.
  12. jack black
    jack black Active Member
    225
    142
    I
    Agree.
    Attention mods, the title needs to be changed to "leak."
    #12 jack black, Jun 15, 2018
    Aaron Vitolins and Grit like this.
  13. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Or the smell of oil when parked at regular spot at home.
    audiodave and Raytheeagle like this.
  14. Mendel Leisk
    42,185
    I think it's the OP's call. But, I'm sceptical you'd "leak" a quart every 2000 miles. I think that's the OP's oil loss rate, it's a little convoluted.
    m.wynn likes this.
  15. Mendel Leisk
    42,185
    More like the lake of oil?
    When I was a kid the cross-the-street and up-a-block gas station did oil changes, and disposed of it by going out the back and pouring it off this small rock bank. That was a nasty little lake of oil. :(
    Grit likes this.
  16. gliderman
    gliderman Active Member
    751
    225
    My oil has never been changed by the dealer. I use the old oil to lubricate the O-ring and never fail to put a filter or new O-ring in. I have no oil leaks. But I do have oil consumption which is about two quarts in 9000 to 10,000 mile OCI. I have my oil tested every time and all looks well. Metals are all below average and viscosity and TBN is strong at 133,000 miles. I wish it didnt burn oil but it is a small price to pay and is considered normal for this vehicle. A whole lot cheaper than new car or engine. I do take good care of it and have only had rough starts a couple of times when it was younger. It is the cheapest car I have ever owned as far as maintenance and has never given me trouble or left me stranded. Except for the tires. But thats not the vehicles fault.
    The metal tab on the oil filter housing is there to stop the cap from getting loose. It is made to move out of the way when a wrench is used to remove the cap and if the filter cap were to loosen it would still hold it from loosening from vibration. So it does work if you dont bend it out of the way.
    YMMV.
  17. Mendel Leisk
    42,185
    Yeah maybe. Still, when I consider the substantial effort I need to exert to get the oil filter started unscrewing (after torque to 18 foot/pounds), that wee piece of plate seems like a butterfly in a tornado, lol.
    send2dan, tpenny67 and gliderman like this.
  18. David Beale
    5,963
    1,989
    Edmonton Alberta
    Never torqued mine, it has never come loose. I screw it in until it "bottoms" but I don't tighten it there. There is no way it would come loose. Torque is also not needed to stop it from leaking. The seal is on the sides of the "can" with the "o" ring. I use grease (lubriplate) on the "o" ring. And I agree with Mendel's comment on the "tab". I can't see it doing anything. My "socket" doesn't touch it and it doesn't stop me from removing the "can".
    Can't comment on consumption, Pearl S has just under 40,000 km on her. If there were oil loss problems at that mileage Toyota would -really- have a problem. ;)
    Fifth oil/filter change coming up in a month or so. So far have trashed only two plastic fasteners. Door hinge still fine. Now that I've said that it will probably fall off this time. ;)
    Andyprius1 and Mendel Leisk like this.
  19. Mendel Leisk
    42,185
    I find backing out the filter cap, I need the wrench all the way, till the O-ring's finally out of the bore.
    Tande likes this.
  20. bisco
    52,692
    have you cleaned the egr and intake manifold?
