(!)exclamation sign
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jebo, Dec 31, 2004.
  1. jebo
    jebo New Member
    davao
    have a used 2001 prius which i bought from japan and bring it home in phillipines. the car didnt came with any users manual with it.
    can anyboby help me out whats wrong with my car? what this sign means? theres "!" on my led panel and "!" with a car sign on my monitor and also theres a warnig marked PS.
    will apreciate any help. thanks!!! happy new year!
  2. Frank Hudon
    Frank Hudon Senior Member
    4,147
    that is the main hybrid problem light and usually needs a trip to the dealer to get the problem fixed. I'm not sure on the Japan version if it has the OBD11 plug to get the codes from the computer. It's normally a serious problem that triggers the ! mark.
  3. Tideland Prius
    16,155
    Doesn't PS stand for Power Steering?
  4. Frank Hudon
    4,147
    It's the general Hybrid failure indicator I've had it on the wife's 2k1 and it truned out to be the aux battery.
  5. Tideland Prius
    16,155
    Ahh okay. Learned something new!
  6. toocean
    toocean New Member
    [font=Arial:ce70337be8]
    I live in England and have a used 1999 Prius which is an import from Japan. Last week the same thing happen to my car, I got an ! in a triangle on the main dash and an ! in a car on the centre console.
    First I thought that it was the 12V battery so I changed that and the problem dissapeared but re-appeared after 24 hours.
    I took it to the local dealer who cannot help as it's an import but the tales I have been getting are freightening. I have been told that either the ECM above the main Nicad battery is gone or the Nicad battery itself is gone and the price for the ECM is £1100 and the battery is £7500, that what i have been told by the local Toyota Dealer.
    So if anyone can enlighten me with better news I will appreciate it very much.
    thanks
    Tim [/font:ce70337be8]
  7. Frank Hudon
    4,147
    you didn't by chance run out of gas(petrol) did you as that will trigger the (!) general hybrid failure light as well.
  8. Poppajack747
    Poppajack747 Junior Member
    67
    Shoreview, MN
    I tried to see how low I could get the tank so that I could see how much it took on fill-up. The last green square was blinking, but I was waiting for a red square. Instead, the triangle with the ! and the check engine light came on. I got gas immediately and it all went away. I hope I didn't ruin something but expect that the warning comes long before tragedy.
  9. jebo
    jebo New Member
    davao
    is there any buttons i could press to reset this warnings? my 2001 prius got warnings allover the screen. exclamations in triangle, exclamation in car , PS warinig on screen. wish somebody could give a hint
  10. nirpoonit
    nirpoonit New Member
    hello i'm a mauritan and bought a prius too and it is indicating the same sign please help me if i anyone have been able to repair your car. my car is the way i earn so please help me. the (!) sign is indicated on the board and a turtle is also shown.
    ps means power supply. you must change the small battery
    i'm from mauritius. i have the same model of prius 1999. i'm getting the same problem and also that the car cannot go through steep roads. it stops i have to wait for the battery to charge then to continue. did you get a manual english medium with the car.
  11. Tideland Prius
    16,155
    <div class='quotetop'>QUOTE(nirpoonit @ Apr 17 2007, 04:12 AM) [snapback]424522[/snapback]</div>
    PS = power steering
    The turtle means your battery is drained and will not be assisting in the propulsion of the vehicle
    The "!" sign inside a triangle is simply a Master Warning Light.
  12. arapberen
    arapberen New Member
    Kenya
    2001 Prius
    Hello Prius gurus, I encoutered a similar problem, might any of you got the solution to the car with an exclamation sign in the middle? The red triangle is hidden on the speed display section at the far right. Kindly help on this. Also, my consumption is abit high, an average of 14KM/Ltr. Your advice will be appreciated
  13. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    How about E-brake? Probably not that, but is your brake fluid down? Hal
  14. arapberen
    Kenya
    2001 Prius
    Hello Hal, My Breakfluid is ok, I still have the sign (a car with an exclamation mark in the middle)
  15. Patrick Wong
    18,200
    6,474
    If you see the car w/ ! warning icon in the MFD, this means that the hybrid system is impaired. You'll need to have the DTC (diagnostic trouble codes) read, in order to have an idea about what is wrong.
