Exhaust heat recirculation question
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Joele3, Jun 1, 2019.
  1. Joele3
    Joele3 Active Member
    118
    189
    Bay Area
    I've been working on the exhaust recovery tank. I was using compressed air to blow out the exhaust actuator. Took awhile to pop that sucker out. When it finally popped out, the actuator and the stopper came flying out into a bucket. Unfortunately I wasn't able to see the orientation of how the stopper goes in. Does anyone have any information regarding the correct orientation?
    From the pictures you can see it marked on stopper. Just want to be sure. I tested the actuator it did pop up but it never went back down to its original spot when I first removed it. Pictured in my hand.
    IMG_0025.jpeg IMG_0026.jpeg IMG_0030.jpeg 58033284092__BF4F1A63-CFBC-4D3A-B044-E46AABFD0178.jpeg Screen Shot 2019-06-01 at 10.37.58 AM.png IMG_0032.jpeg
  2. Mendel Leisk
    38,726
    SFO and Raytheeagle like this.
  3. Joele3
    118
    189
    Bay Area
    You can see on the stopper it has a channel on one side. Should the channel be facing the actuator or away ? Thanks for posting the diagram.
  4. Mendel Leisk
    38,726
    See what you mean. Might be more info in the attached pdf, not sure.
    Isn't that a brilliant instruction:
    Be sure to install the exhaust pipe gas control stopper in the correct direction.
    #4 Mendel Leisk, Jun 1, 2019
    CR94 likes this.
  5. Mendel Leisk
    38,726
    Ah, maybe the channel on the stopper faces away?
    SFO and Joele3 like this.
