Exhaust louder after recall software update
Discussion in 'Gen 3 Prius Main Forum' started by MattFL, Jun 17, 2019.
  1. MattFL
    MattFL Member
    193
    57
    Has anyone had the recent software update recall done and did you notice the exhaust was louder after the recall? I screen shot of what they did is below.
    Our 2012 is my wife's car that I only drive occasionally so I'm not 100% positive that it happened exactly with the software update, but I drove it shortly before the update and all ways normal, and I drove it about a week after the update and when sitting still the exhaust is a lot louder inside and outside the car than it was before the update. It sounds as if there is an exhaust leak and/or the engine is running at a higher RPM than it did (when sitting still). I looked briefly under the car and did not notice anything obviously wrong, I suppose I need to jack it up and really have a good look, but has anyone else noticed the same after the update? It seems to drive normal and mileage is normal.
    52,758
    how many miles on her? could she have run over something?
    i don't recall reading of this problem before. lower mpg's and less power, yes.
  3. MattFL
    MattFL Member
    193
    57
    Just shy of 70k miles. Drove about 5 hours a couple days ago, 75-80mph most of the way and about 42mpg trip average according to the cars computer. Everything appeared normal except for the louder exhaust when stopped.
  4. CR94
    CR94 Senior Member
    2,814
    1,235
    Northwestern S.C.
    Coincidence
  5. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Didn't happen on mine.
  6. bisco
    52,758
    did your wife notice anything in the week before you did?
  7. MattFL
    MattFL Member
    193
    57
    I don't think she would notice if the entire exhaust fell off.. unfortunately.
    Raytheeagle and bisco like this.
  8. bisco
    52,758
    been there :cool:
    Mendel Leisk and MattFL like this.
  9. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    BUT......you really should check it out thoroughly because an exhaust leak can be DEADLY under the right circumstances.
    If it really is louder because the engine is running faster, this is sometimes an early sign of HV battery failure.
  10. MattFL
    MattFL Member
    193
    57
    On my quick inspection it sounded like all of the sound was coming out the tailpipe, but I will jack it up and get under there for a closer look. Thanks for the tip on the HV battery, I'll keep a close watch on that. Am I right in guessing that city mileage is the first thing to go when the HV battery begins to fail?
  11. sam spade 2
    7,035
    2,804
    2017 Prius c
    And the engine runs more.
  12. MattFL
    MattFL Member
    193
    57
    So far that's normal.. though the HV battery fan runs almost all the time, and has since we got the car. I'm in a warm climate though..
  13. bisco
    52,758
    nothing you can do about the hybrid battery except make sure the intake grille is clear, and the fan is clean
