Exhaust manifold flange gasket blown
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by anonymous, Jul 1, 2021.
  1. anonymous
    anonymous Member
    177
    104
    US
    H... How?
  2. PriusCamper
    PriusCamper Senior Member
    13,416
    5,416
    Pacific Northwest, USA
    Yep... Once the Catalytic converter gets clogged up it's the path of least resistance for exhaust gas as the bolts for that gasket are on springs to protect the connection from bumpy roads so it doesn't take much internal pressure to blow out that gasket.
    maleko likes this.
    52,791
    how many miles on her?
  4. anonymous
    anonymous Member
    177
    104
    US
    Huh... I wonder how much back pressure there might be. I suppose it also got very hot to disintegrate the gasket material, and the wire mesh is brittle and disintegrating.
    So I have to order a replacement gasket, but what's gonna stop it from blowing out again? I guess I'll have to fix the restriction as well.
    For now all I could do is smother max temp silicone (750°F) over it but this joint probably gets way too hot for it.
    260k
  5. anonymous
    anonymous Member
    177
    104
    US
    Here's some more pics if anyone's interested.
    IMG_20210701_121706.jpg IMG_20210701_121752.jpg IMG_20210701_122337.jpg IMG_20210701_122443.jpg IMG_20210701_121426.jpg
    wheezyglider likes this.
  6. PriusCamper
    13,416
    5,416
    Yeah, I learned the hard way that replacing the flange gasket without first making sure the cause of its failing was address is pretty much always an epic waste of time. But at least I learned to never be that optimistic again and can warn others of the same? :)
    Samuel Williams Jr and bisco like this.
  7. PriusCamper
    13,416
    5,416
  8. anonymous
    anonymous Member
    177
    104
    US
    It was already like that, and I've never had the union apart before, shrug
    PriusCamper likes this.
  9. PriusCamper
    13,416
    5,416
    In looking at pics again it seems like your gasket blew and it damaged your cat too... Replace it w/$200 version and move the registration out of California!
    maleko likes this.
