hi all… can anyone clarify or define what a normal range of exhaust temps on our third-gens would be? for reference i’m in houston, and the temps i was looking at were while driving at 50-60mph and during 70f weather… i am deriving my temps from readings of the sensors labeled catalyst temperature sensor 1 b1 catalyst temperature sensor 1 b2 i am regularly seeing temps like 1347/1270, that being sensors 1/2… is this normal? it seems overly hot to me, i was standing behind the car while it idled and the exhaust felt a lot hotter than i expected… is this overly hot? and if so, what would that be a symptom of? thx in advance for any insight friends!
There are no sensors, those temperatures are estimated. If you have a P0420 or are burning a lot of oil the cat may be getting clogged or you might look at fuel trims as Tom suggests.
Yeah... Seems you have to confirm or deny those temp readings. Maybe using a thermal camera to get reading of metal temperature from exhaust header to tailpipe. Any other symptoms like bad MPG or sluggish engine performance? Also the EGR system helps lower engine combustion chamber temperature for cleaner burning, but they tend to clog quickly due to a faulty design in Gen3 Prius. Have you ever had yours cleaned?
