  1. Archimedes
    Archimedes Junior Member
    70
    45
    Anyone install a custom exhaust on their Prius yet? Any significant difference in performance or MPG?
    49,694
    welcome! nope. the system is optimized at the engineers desk.
    RCO likes this.
  3. Archimedes
    70
    45
  4. Archimedes
    70
    45
  5. bisco
    49,694
    yes, unless you prefer the look. i suppose it's possible to increase mpg's at the risk of fuel usage and increased admissions. some of the nodders may have better ideas for you.
    RCO and Archimedes like this.
  6. Archimedes
    70
    45
  7. Archimedes
    70
    45
    bisco and RCO like this.
  8. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    Modder= someone who changes or modified their original equipment (on their car in this case).
    krmcg and bisco like this.
  9. bisco
    49,694
    you're in the right forum, just have to wait for the posts. look for my owl.
    krmcg and Archimedes like this.
  10. JimboPalmer
    12,470
    6,870
    Greenwood MS USA
    You can certainly make the car louder. Most who felt they needed their Prius louder, found that it is a particularly unpleasant exhaust note.
    The Atkinson cycle engine has a compression ratio of 8:1 and an expansion ratio of 13:1, (in an Otto cycle engine, they would be equal) so its exhaust is at much lower pressure than you may be used to. I suspect it is optimized for MPG, no performance is going to happen without negating the Atkinson cycle. (perhaps to Miller cycle^, or Otto cycle*)
    *The 1.8 liter engine is available as an Otto cycle engine that would be drop in, for a 39 HP increase, if you don't care about MPG.
    ^Turbocharging or supercharging can be added, but you will not find a kit, it will all be fabricated by you and under hood space will be cramped.
  11. Archimedes
    70
    45
    Head input, thanks. I'll just save up for a carbon fiber hood and carbon rims for weight reduction.
    RCO and bisco like this.
  12. JimboPalmer
    12,470
    6,870
    Greenwood MS USA
    There was an entertaining 5 part article about supercharging and then the same author had a 5 part on turbocharging a Gen 0 Prius.
    He could not make the supercharger quiet enough so his SO would ride in the car. It made more horsepower but he was surprised to discover that this mostly charged the battery quicker.
    AutoSpeed - Technokill: Building a Blown Hybrid, Part 1
    The turbo was inherently quieter, but his plumbing was so convoluted that he was not getting as much horsepower.
    AutoSpeed - The Story of Turbo'ing a Hybrid Prius, Part 5
  13. Toppcat
    Toppcat Member
    223
    69
    Northern California
    Prius are design to deliver maximum torque at the low rpm's using the lease amount of fuel! modifing to a less restrictive exhuast may yield 1-2 HP only at high rpm's like 5'000+ but you would lose lots of low end torque and your mpg will suffer Big time!
  14. DeadCannon
    DeadCannon Junior Member
    KY
    Something else to consider with the wheels is aerodynamics. A friend of mine put Enkei RPF1s on his Insight and after a couple weeks noticed his fuel mileage was getting worse. Even though they were lighter the more open face and lip was creating more drag and making the car work harder once it was up to speed.
    BLITZ XW50, RCO and Archimedes like this.
  15. bob2004
    bob2004 New Member
    Illinois
    RCO likes this.
