Expansion valve - how to replace
Discussion in 'Gen 2 Prius Technical Discussion' started by Wecandothat4u, Sep 13, 2024 at 7:06 PM.
  1. Wecandothat4u
    Wecandothat4u Junior Member
    28
    Cambridge, MN
    I've searched both Prius chat and Youtube and found nothing on this. Apologies if it is in plain sight and I am not seeing it. And this might not even be the problem, but we have high pressure of 350 with less than one can of freon after replacing the condenser with a brand new one. We've actually just replaced the engine and some other stuff, but this is one of the last issues. We're thinking the expansion valve might be the culprit. Where is it and how much must be disassembled to replace it? We have a parts car where the AC was working fine, so parts are right there. Thanks in advance.
  2. Leadfoot J. McCoalroller
    7,263
    6,787
    Pennsylvania
    2018 Prius c
    Not common as a DIY repair so there may not be many DIY info sources.
    But there is the OG factory repair manual- probably well worth the rent for a job like that.
  3. ChapmanF
    15,983
  4. mr_guy_mann
    mr_guy_mann Senior Member
    3,583
    1,644
    NJ-USA
    How long did you run your vacuum pump to evacuate the system before charging? What vacuum reading did you achieve? Do the radiator fans operate when the A/C turns on?
