Expense Accounts
Discussion in 'Prime Main Forum (2017-2022)' started by RJ Primw, May 29, 2017.
  1. RJ Primw
    RJ Primw Member
    65
    87
    South Jersey
    My company reimburses travel expenses each month. But, instead of the IRS rate, we are reimbursed for the actual cost of fuel and tolls. Traditionally, it's calculated by taking the amount you spend on gas each month and use a ratio to calculate the cost of business miles as opposed to total miles driven in a given month. (Business miles/total miles x gas cost).
    Needless to say, a plug does not work with this calculation at all. I continue to be reimbursed for gas costs, but not for electric costs. I have two colleagues with Volts and we are trying to come up with a solution that will allow us to be reimbursed. It needs to be a fairly simple formula, because we don't want to invest an inordinate amount of time on record keeping or calculations. Any solution ideas would be appreciated.
  2. crewdog
    crewdog Acting Ensign Prius Prime
    493
    388
    Woodstock, GA
    I think you'd probably have to log each trip and note the avg mi/kwh figure and log your charging noting whether at home using residential kwh rate or at a public station at the $1 plus/hr rate; then add it all up at end or reporting period, and include gasoline used.
    Pain in the rear, but if you were self employed or independent contractor, the IRS may ask for documentation like that if they audited you.
    If your company requires receipts; maybe a camera phone picture of a charge completed notice would work.
    Good luck.
  3. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    Get a juice plug
    posted via my Athiest phone
  4. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
    I calculate my cost this way: 6.28 (kWh for full charge) *$.15 (my elec cost) = $.942 (cost of a full charge). Then multiply that by your charge ups since your last report.
    ArcPrime and RJ Primw like this.
  5. bisco
    52,371
    how much plugging in can you do when traveling for business?
  6. Rightrudder
    Rightrudder Member
    49
    59
    Nazareth, PA
    If my company reimbursed my actual fuel costs I would be driving around in Force Charge mode to use when I was off the clock
  7. ArcPrime
    ArcPrime Active Member
    201
    166
    Arcadia, California
    How about using ChargePoint charges KWH per mile then multiple miles you use? I paid about 6-6.5 cents per mile. Home charge is about half of that?
    Prius from Dad likes this.
  8. RJ Primw
    RJ Primw Member
    65
    87
    South Jersey
    Very little, actually. Almost all of my charging is done at home. Most of the travel is same day, in state, to places that do not have charge stations close by.
  9. RJ Primw
    RJ Primw Member
    65
    87
    South Jersey
    This might well be a do-able solution. I'll have to take it to HR to suggest.
  10. Prius from Dad
    724
    1,116
    Toms River, NJ USA
    Yes, my cost is about 2.86 cents per mile @ 15 cents per kWh. 6.28 (full charge)*.15(elec co. charge) /30 (EV miles per charge) =$.0286 (cost per mile) . ymmv ;)
    JoePriusPrime likes this.
  11. stevepea
    stevepea Senior Member
    535
    581
    For my local Power Co, you can log in and see your hour-by-hour usage, and extract from that the cost of charging (for instance, if your usage from 1am to 5am is typically 16c worth but on the day you charge it's $1.16 worth, then you know you spend $1 on charging). Works for me, but it's not "official" since you can't actually separate officially the charging $ unless you have a separate meter. If your employer is fair you can show it to them, but, hmm... also remember that many power companies, if you use a lot of electricity, you might be put into a higher tier -- in which case the "cost" of charging not only is for charging the car, but for your other electricity needs (if car charging makes your kw/h rate go into a higher tier).
  12. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Being reimbursed at a standard rate, compensates for fuel, deprecation(wear and tear, and mileage), insurance, and maintenance.
    I would have a problem only be reimbursed for one.
    You get paid for the time in the car as well ?
    jp
    alexcue and bwilson4web like this.
  13. Prime8
    Prime8 Member
    Oregon
    2020 Prius Prime
    I concur.
    Federal rate for 2017 is $0.535/mile.
    This was a significant factor in the ROI math that endorsed the Prime over all others. It reduces the expenses that I am reimbursed for at a fixed rate. It provides me with an incentive to get the fuel portion of that math down to $0.035/mile, which the Prime can do.
    ruby likes this.
  14. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Get a letter from your employer that they require you to use the car. Buy one of those blank accounting books and record your mileage, where your drive from, where to, and for what reason. time and date each entry.
    You'll be able to deduct the standard rate from your taxes, minus the amount your employer pays.
    #14 I'mJp, May 30, 2017
    fuzzy1 likes this.
