Extended Warranty: What do you really get?
Discussion in 'Gen 2 Prius Main Forum' started by paulrubin, Aug 25, 2007.
  1. paulrubin
    paulrubin New Member
    32
    If the hybrid system itself is covered to 100K (some components more in certain states) and the powertrain to 60K, and most everything else to 36K and the extended warranty eliminates the following list of items:
    * Brake linings, pads, and shoes
    * Accessory drive belts
    * Spark plugs
    * Carpet
    * Chrome
    * Hoses
    * Rust and corrosion damage
    * Fluids
    * Seat covers
    * Dash cover and pad
    * Headliner
    * Filters
    * Clutch Friction disk and pressure plate
    * Interior/exterior trim/moldings, including but not limited to, cup holders, ash trays, covers, vents
    * Windshield wiper blades (rubber component)
    * Door trim, handles, and fabric
    * Tires
    * Paint
    * Glass (including windshields)
    * Batteries
    * Bumpers
    * Shiny metals
    * Weather stripping
    * Nuts, bolts, clips, retainers, and fasteners
    * Hinges
    * Light bulbs
    * Vacuum hoses, lines & tubes
    * Heating hoses, lines & tubes
    what precisely am I paying just under $1000 (a good price) or ripped off closer to $2000 for? From the sound of things, it almost seems as though the extended warranty only gives you 40,000 additional mileage on some of the powertrain that isn't considered part of the Hybrid system and the features of AAA (roadside assistance type stuff).
    Now that's not to say I expect every aspect of the car to be covered through 100K. Hell some of it might even be an issue with Toyota for 1K such as brakes, small light bulbs, the 12v battery, tires, glass, etc. At an anticipated 30K a year, it almost seems as though I'd be paying $1000-$2000 to cover me for a very precise 16 month period on the engine and a handful of other powertrain components and since sometimes you can negotiate a bit with toyota if you're somewhat over the standard warranty by a bit, it might be closer to 12 months.
    Some of these items not covered under the extended warranty make no sense. Hinges? Why not? The door handle? Come on. What about the real stuff, the meat and potatoes. The expensive non powertrain stuff. For example, the MFD, or components related to it like the nav system? What about the power windows, locks, etc. Or the security system. What about if my Fob stops working and it's not a battery. How about the engine for the wiper blades or the high intensity headlight system? The climate control system? Can somebody give me a straight answer on what expensive components are going to be covered under the extended warranty from 36,000 miles to 100,000 miles.
  2. dogfriend
    7,512
    1,187
    Carmichael, CA
    <div class='quotetop'>QUOTE(Paul R @ Aug 24 2007, 09:26 PM) [snapback]501891[/snapback]</div>
    ECU(s). There are a bunch of them. They don't seem to be excluded on your list and they are pretty expensive.
    However, I'm not a big proponent of extended warranties. On something as complex as the Prius, they might be a reasonable precaution if you are not a technically oriented owner, but I have thought that for myself, a good scan tool might be a better investment.
  3. EarthFriendly
    EarthFriendly New Member
    I had a hard time getting an answer on this when I asked at the dealership. I was pretty amazed actually when the salesperson told me that I had no choice in spending $990 to extend the powertrain to 100k. He told me that the Prius, Camry Hybrid, and Highlander Hybrids are in such high demand that the dealership essentially forces you to pay for the extended warranty because they know the demand for the cars is high, and that someone will pay for it. That someone happened to be me, because, frankly, I really wanted the car. I did feel like it was dirty pool, though.
  4. paulrubin
    32
    Well I already have a contract on a specific car so I don't anticipate being forced. However I do plan to do nearly 30K a year and want to at least cover myself for close to 4 years hence 100K warranty. I'm just concerned about the use of the word accessory in terms of what's covered and what's not.
  5. Malarkey
    Malarkey New Member
    146
    Connecticut, USA
    <div class='quotetop'>QUOTE(EarthFriendly @ Aug 25 2007, 12:44 PM) [snapback]502008[/snapback]</div>
    There's a window in which you can cancel those for no penalty, I thought... ? If so, and the dealer refuses, I'd contact Toyota corporate and tell them which dealership and who you're specifically working with there. I'd tell the dealer you're doing it, too, and see if they change their tune.
  6. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    Take a look at this Service Agreement Comparison chart.
  7. mcbrunnhilde
    mcbrunnhilde Opera singin' Prius nut!
    612
    23
    My two reasons for getting the extended warranty:
    1. 2004 was the first model year of a redesign. EVERY redesign from every manufacturer has more problems than previous or subsequent years.
    2. There was a known problem with the MFD, and mine didn't crap out before the standard warranty was up.
    If my MFD had gone out before 36,000 miles, I *might* have passed on the extended warranty. If I had purchased a 2005, 2006, or 2007, I would not have gotten it, under the assumption that they would have ironed out the bugs by that time.
  8. paulrubin
    32
    <div class='quotetop'>QUOTE(IsrAmeriPrius @ Aug 25 2007, 11:20 PM) [snapback]502215[/snapback]</div>
    This was very helpful. I tried to find it earlier in the week and came up empty. Now I can actually see what's covered and what's not. I can also bring it with me to the final signing of all the papers so when they start badgering me that it has to be done now, and the price is whatever nonsense they offer, I have something concrete to respond with.
  9. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Well, part of it is that was when, and part is this is now. In 2004 it may have been a good bet, no one knew how the new model would go. Now I would be more cautious. The present design appears to be fairly stable though the warranty period and less of a value than in 2004. It is like all gambling, there are losers and winners. What can one say.
  10. patsparks
    10,664
    567
    Adelaide South Australia
    Waste of money I think. :angry:
    1 in 100 chance you might make a claim on the warranty and that claim will most likely be less than the premium paid.
    Lets say you get the warranty and the most likely thing happens, no claim. You're out of pocket $1000 to $2000.
    Now lets say you don't get the warranty and the MFD goes night night. You're out of pocket about $1000 maybe.
    Now lets say the most likely thing happens, no problems and you have no extended warranty. You're already $1000 to $2000 closer to a new Prius with another 3 years factory warranty.
    The battery and HSD are still covered by the factory warranty for the period of the extended warranty anyway.
    It's a Toyota, that's warranty enough for me. :D
  11. Godiva
    Godiva AmeriKan Citizen
    10,339
    Piece of mind.
    I usually don't buy extended warranties on anything, but I made an exception for the Prius because of it's complexity and it's still relatively new (and complicated) technology.
    If I had passed I'm sure something expensive would have needed repairing right after 3 years/36,000 miles. Now that I've purchased it I'm sure nothing will happen until after the 7 year/75,000 miles the warranty covers. By that time I may already have traded it in.
  12. Boo
    Boo Boola Boola Member
    5,051
    485
    97
    Flushing, NY
    Notwithstanding Toyota's bullet-proof reputation, it is not immune from what is usually the weakest link or Achilles Heel of all autos --- the electrical system. Take a look at Consumer Reports' Frequency of Repair charts for Toyotas going back a few years. I think that you will find that if there are any black circles, black half-circles or clear circles, they almost always involve the car's electrical system. And the advent of computers and ECUs throughout cars has only made things worse (see e.g., Mercedes or Volvo, or better yet --- the first generation Prius).
    I think that for $990 on PriusChat, the Platinum Care extended warranty is a good deal, especially for a car like the Prius. Dealers charge a lot for repair work. If anything goes wrong, the warranty is likely to pay for itself (or several times over given how expensive it is for dealer repair work) on the first repair under extended warranty. I'm going to get it myself for my 2007 Prius pretty soon. I think you have like 3 years/30 something thousand miles to elect to get it. But I'm going to get it soon because I'm a little afraid of a possible rate hike (I believe that the MSRP for the extended warranty went up sometime during the past 6 months from $1600 to $1800).
  13. galaxee
    galaxee mostly benevolent
    9,810
    466
    MD
    our reasoning has always been that parts are really expensive! even though DH could diagnose and fix anything that would go wrong, thereby eliminating labor costs altogether, some of those parts go pretty damn high in price. and we have terrible luck, in case anyone hasn't noticed :lol:
  14. apriusfan
    apriusfan New Member
    6,050
    205
    S.F. Bay Area
    <div class='quotetop'>QUOTE(galaxee @ Aug 26 2007, 10:10 AM) [snapback]502378[/snapback]</div>
    But for everyone else, labor rates can take their pound of flesh (so to speak). The bottom line on extended warranty is how badly do you want peace of mind? If you are wanting some uncertainty in your life, pass on the extended warranty. If you don't want any un-expected events costing you a bunch of cash (otherwise known as peace of mind), then it would seem the extended warranty is something to get.
  15. galaxee
    9,810
    466
    MD
    i was saying that's why we bought the EW... parts alone are expensive enough, nevermind the rest of it. and like i said, we're rather unlucky folks.
  16. bobdavisnpf
    bobdavisnpf Member
    149
    I feel like all I got is screwed.
    Bought the platinum policy from the dealer for $1695 per car. Even told 'em I was paying more to buy from them because I expect the extra margin to buy me some level of "above and beyond" care.
    Got a 4-wheel alignment on the '05. Came up in the red on the left rear toe-in. Got a 4-wheel alignment on the '06. Came up in the red on the right rear toe-in. Independent shop and dealer both agreed on the out-of-spec condition and the lack of adjustability. Dealer said the solution is to rotate tires regularly and not worry about it. Warranty provider (turns out it's not a Toyota policy) refused to cover since they contend alignment is a wear item. Dealer and regional factory rep have each independently inspected and state there is no damage, no defect to repair, no basis for assuming replacement parts ($1800+) would correct the condition.
    Dealer's cancelling the policies and getting checks mailed back to me, but their only suggested recourse is to pursue through the state's lemon-law system, when I explained what would really satisfy me is to get 2 Prii - these or 2 others - to come up in the green on the rear alignments.
    In a way I feel like I'm splitting hairs. I never knew about the problem til I got the 4-wheel alignment, something many owners never do or just don't get the reports for. But after shelling out MSRP plus service and warranty contracts, I expect every little out-of-spec thing to be fixed and fixed free. And at this point I feel like there is no component a warranty claims person would have to pay on: there must be a way out of every possible claim situation.
  17. Godiva
    10,339
    <div class='quotetop'>QUOTE(bobdavisnpf @ Aug 26 2007, 02:06 PM) [snapback]502434[/snapback]</div>
    Would getting a real Toyota extended warranty from Troy for both cars for almost what you originally paid for one be something you would consider? There's a lot more to deal with than alignment. I think $1700 per car is a ripoff. But I think Troy's price is reasonable. It gives me 7 years of piece of mind. Of course, so far my dealership hasn't tried to $crew me like your's has to you.
    And I disagree with your dealer. If both are out of alignment and can be fixed, it should be fixed. AND under warranty. Seems to me I read on Priuschat about someone having this problem and it getting if not fixed, then improved.
  18. dogfriend
    7,512
    1,187
    Carmichael, CA
    <div class='quotetop'>QUOTE(bobdavisnpf @ Aug 26 2007, 12:06 PM) [snapback]502434[/snapback]</div>
    I also had the RR toe in out of spec on my 07. Dealer basically fudged the data instead of fixing the car. Details in this thread. I ended up shimming the axle with shims provided by Galaxee and her DH (thanks again BTW). I recommend this approach if the dealer won't fix it; its pretty easy and will save your tires.
