extended warranty what does it cover and should I get it?
Discussion in 'Gen 2 Prius Main Forum' started by karynfab, Mar 25, 2008.
  1. karynfab
    karynfab New Member
    I am confused as what it DOES cover.
    I am almost at 3 yrs. 19,700 miles. Obviously I don't drive too much.
    So what does it cover?
  2. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    Deleted. Error.
  3. Boo
    5,051
    483
    97
    Flushing, NY
    Hi Karyn,
    Here's the Toyota Financial web page describing the benefits, components and MSRPs of the different extended warranties.
    In order to see all of what's covered, make sure to use the tabs on top, and any drop down menus.
    Toyota Financial Services
  4. Boo
    5,051
    483
    97
    Flushing, NY
    Whether to get the extended warranty is completely up to you. It's been discussed ad nauseum here on PriusChat in tens and tens of threads. Here's the results page of all thread titles with the words "Extended Warranty" in it:
    PriusChat Forums - Search Results
    Good luck.
  5. aaf709
    3,862
    2022 Prius Prime
    There's an interesting article on extended warranties in the April car issue of Consumers Report that might be worth reading.
  6. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Forget that site's priicing. The coverage is avalilable here for much less.
    I did not buy the extended coverage and after reading many posts about what is not covered and whether it is a component or an assembly, I'm glad I didn't.
  7. Boo
    5,051
    483
    97
    Flushing, NY
    Of course, that's why I said it was MSRPs. The price here for any plan is around 45% off the MSRP.
  8. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    I take it you thought the warranty did not cover much or they had a lot of loop holes?
  9. richard schumacher
    7,663
    1,038
    United States
    "...and should I get it?" No. Save your money. There is no car less in need of an extended warranty than a Prius. See the April 2008 issue of Consumer Reports.
