extended warranty worth it, 2010 Prius 70K miles?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by gychang, Apr 8, 2016.
  1. gychang
    gychang Junior Member
    Davis, CA
    I think my 12V battery maybe dying?, one time had to call toll service and started and drove around and got it recharged one month ago and no more problems (? left inside light on) without changing the battery.
    Live in California is the 12V battery likely gone bad?
    Is the extended warranty worth $1,500 dealers want?
    thanks,
    lar.smith42 likes this.
  2. JC91006
    16,769
    8,567
    Yes replace 12v, no warranty no worth it
    SM-N900P ?
    51,976
    how long is the warranty for, and what does it cover?
    12v may need replacing, you should check the voltage. you say it's been starting fine since you jumped it a month ago?
  4. ForestBeekeeper
    ForestBeekeeper Active Member
    772
    304
    Maine
    Replace the 12vdc battery on your own, do not use the dealership to do that.
    No, the extended warranty is NOT worth it.
  5. lar.smith42
    lar.smith42 Active Member
    203
    118
    Double Oak , Texas
    I have a 2010 with 66,000 miles bought 2 years ago. Just had dealer install new 12 volt batt. for $229. Orig. batt only last about 5 or 6 years in Texas heat. I got the extended warranty from dealer for piece of mind and already save about $1500 on front drive axel assembly that when bad.[/QUOTE]
