Extension cord use for the plug in Pirus
Discussion in 'Newbie Forum' started by mbaumann, Sep 30, 2012.
  1. mbaumann
    mbaumann New Member
    Good idea or bad idea? I could plug in at work with an extension cord.
    49,500
    welcome! no problem using cord, but do some research on length and gauge. 12 gauge 25' is common. all the best!
  3. mbaumann
    mbaumann New Member
    Thank you!
  4. NinnJinn
    NinnJinn Member
    276
    Indiana
    Just like Bisco said, Make sure you have a big enough gauge wire to prevent cord over heating.
  5. David3433
    David3433 Junior Member
    California, USA
    2018 Prius Prime
    I should have known better, but I used a too-small-gauge extension cord when charging at work. The cord's resistance-heat was high, but I didn't realize it - I assumed that the extension cord's heat was due to solar absorption from Southern California's currently scorching sun. Over the course of 2 weeks of charging, there was enough overheating to slightly melt plastic at the wall receptacle-to-plug interface. I'll be getting a 12 gauge extension cord.
  6. Smaug1
    Smaug1 Member
    135
    95
    Chicago suburbs
    2018 Prius
    The plug prongs melting is also due to a sub-par spot welded wire onto the prongs inside the molded-on plug and receptacle.
    When you get the larger cord, also buy separate UL Listed plug and receptacle. Cut off the stock ones, (or just buy the cable alone) and wire them on yourself. You'll lose less power to heat and won't melt anything.
    (I'm an electrical engineer, by the way)
