Extra Amps
Discussion in 'Gen 3 Prius Accessories and Modifications' started by RoastyToasty, Oct 5, 2009.
  1. RoastyToasty
    RoastyToasty New Member
    Ann Arbor, MI
    Just got my new Prius and was hoping I could get some info on boosting up my performance a little. The 201.6 Volts currently provided in my Prius isn't doing it for me. Has any one added an extra battery and ran it in series to boost power output? Imagine the look of the Camero or Mustang next to me as I roast the tires on my Prius. I think I'm going to give it a shot. Any feedback would be greatly appreciated.
  2. sciguy125
    sciguy125 Junior Member
    CA
    It's not going to be that simple. The first problem is that that battery goes into an inverter before getting to the motors. The inverter is going to regulate the output to whatever it thinks it's supposed to be (if the extra input voltage doesn't kill it). You'd also need to tell the computer about the mod. That might be next to impossible for a homebrew mod.
  3. EZW1
    EZW1 Active Member
    722
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Plus, the extra voltage means extra power dissipated by the inverter and that equals extra heat and that means extra shortened liftime. Not to mention how 'extra' fast you'll blow the warranty out of the water.
  4. ken1784
    ken1784 SuperMID designer
    2,940
    1,365
    67
    Yokohama, JAPAN
    It is not that simple.
    Do you know there is a step up DC/DC converter and the 201.6V becomes up to 650V?
    If you have enough hacking capability, you had better to add second pack connecting in parallel.
    The Toyota's gen2 plug-in prototype Prius increased the system power to 100kW by paralleling the battery.
    TOYOTA: News Releases: Toyota Plug-in Hybrid
    The TRC does not allow you to wheel spin.
    Ken@Japan
  5. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Rather than try to make the Prius powerplant what it is not, here are some (silly) ideas.
    Mid engine rear wheel drive V8 that spend most of it's life in Neutral.
    Cast a mold of the Prius body and make a fiberglass shell, mount the shell on an Ariel Atom
    Welcome to Ariel Atom
    Mind you, an Australian gentleman has both supercharged and turbocharged his Gen I Prius, so it CAN be done. I keep thinking of a 201V electric supercharger project... the Road Watt-ior
    Most of this guys problems would be solved if he was using a 201 volt motor. http://www.turbomagazine.com/tech/0406tur_knight_turbo_electric_supercharger/index.html
  6. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    Can you say drivetrain? Surely the Prius' drivetrain is matched so that it is handling all the power it can. To oversize the drivetrain would be inefficient. I assume you can't tow with a Prius for this reason, the drivetrain won't handle it.
    I bet the Prius has traction control that you can't turn off for this reason as well, that is the sudden "grab" of traction when a wheel stops spinning is more than the drivetrain can handle.
    Most cars that have traction control have a way of disabling this feature, for snow, ice, etc. , but you can't turn the traction control off in a Prius, Why?
  7. a64pilot
    771
    62
    Albany Ga.
    Sell the Prius and buy whatever car is being modded now, I just don't think you will be happy with it.
  8. Guy in WNY
    Guy in WNY Junior Member
    83
    17
    Western New York
    2018 Prius Prime
    Just drop in another complete drivetrain, complete with another battery, in the back. Or just go buy a used Corvette - they are cheap enough and probably a blast to drive! and will really smoke up the tires for you.
