Extremely loud banging in rear 2012 Prius v
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Reed Cox, Apr 30, 2018.
  1. Reed Cox
    Reed Cox New Member
    Anderson Indiana
    My 2012 V started occasionally making an extremely load banging in the right rear. Toyota replaced the at its and shocks but it still occurs. It is very intermittent and sometimes is one loud bang and sometimes multiple quick bangs for a couple of seconds. I have had it to two Toyota dealers and one independant mechanic and no one seems to be able to find the cause.
    Any ideas?
  2. Reed Cox
    Reed Cox New Member
    Anderson Indiana
    Correction....struts and shocks.
  3. Air_Boss
    Air_Boss Senior Member
    4,140
    1,154
    New Yawk
    Occurs when moving? Braking? Loaded? Frequency change with speed? A bit more information required.
    Raytheeagle likes this.
  4. Reed Cox
    Reed Cox New Member
    Anderson Indiana
    Occurs very occasionally when hitting small bumps. Not so much on bigger bumps.
    Very intermittent and follows no pattern. Sounds like something is coming through the rear floorboard or trunk area.
    Only occurs when moving and usually at slower speed. Can occur when turning as well.
    #4 Reed Cox, May 2, 2018
  5. mikefocke
    3,902
    1,758
    Sanford, NC
    Something loose under the rear floorboards? Spare tire well?
  6. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    662
    263
    Dodge Co. Wisconsin
    2017 Prius v wagon
    Exhaust?
  7. lostinheadguy
    lostinheadguy Junior Member
    67
    48
    United States
    2013 Prius v wagon
    I had a similar issue with my previous vehicle that turned out to be the rear sway bar end links. They were still attached, but the bushings were busted so they and the sway bar itself would occasionally clang around when going over small bumps while turning, going into the driveway, etc... It wasn't dangerous at the time but the noise was definitely unexpected and startling.
  8. Air_Boss
    4,140
    1,154
    New Yawk
    You've pulled the tire or been underneath and seen bump stops intact and nothing hanging? Anything loose in the spare tire well? Is the headlight self-leveling mechanism free to move?
  9. Reed Cox
    Reed Cox New Member
    Anderson Indiana
    Thanks!
    I was hoping both the Toyota dealers checked but I wouldnt swear to that.
    Thanks!
    I'm reasonably sure the dealer checked.
    Thanks
    That may be worth a look.
    I told the dealer what I heard and would hope they checked.
    I did not pull the sare but I will.
    Thanks!
    #9 Reed Cox, May 3, 2018
  10. bisco
    51,155
    sounds like suspension rubber bits, see post #7. how many miles on her?
  11. Reed Cox
    Reed Cox New Member
    Anderson Indiana
    First problem I've had with this car.
  12. bisco
    51,155
    can't argue with that.(y)
