Extremely low mileage
Discussion in 'Gen 3 Prius Fuel Economy' started by brianmiami, Jan 21, 2019.
  1. brianmiami
    brianmiami New Member
    My Prius 3 2016 is three year's old. When I fill up my tank it says 435 miles until
    I need to fill up my tank again. Do I have a bad battery?
  2. brianmiami
    Prius 2015 I mean
  3. cnc97
    cnc97 Senior Member
    1,419
    1,528
    38
    Evansville, IN
    That’s pretty normal for fuel range. The range is based on your consumption # times gallons of fuel remaining in the tank. Mine shows on average 416 to 480. I’m in SW Indiana, and the temps are running in the 30’s to 40’s. The warmup penalty is a pain in the asterisk.
  4. AndrewR
    AndrewR Junior Member
    SF Bay area
    2014 Prius c
    Mine does the same do a visual week to week check
  5. solrunner
    solrunner Member
    114
    37
    Reston, VA
    435 is similar to what I see. I live in Virginia.
    iPad ?
  6. bisco
    49,435
    it doesn't use reserve gallons in the equation, just capacity from full to blinking pip.
    you're better off to start measuring your fill ups and computing mpg's. keep a record for average, this will help you determine any future problems
    DeezPrius likes this.
  7. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    You should post this in the correct sub forum, you'll get ball park explanations.
  8. fuzzy1
    10,167
    Never mind that guestimated forecast, which is sandbagged by a significant safety margin.
    What MPG are you getting? That is what matters.
