ez pass question
Discussion in 'Gen 2 Prius Main Forum' started by SureValla, Aug 30, 2007.
  1. SureValla
    SureValla Member
    590
    Shelton, CT
    Do I need to notify ezpass when I change my license plates?
  2. fred s
    fred s New Member
    67
    Coram, NY
    <div class='quotetop'>QUOTE(SureValla @ Aug 30 2007, 09:09 PM) [snapback]504626[/snapback]</div>
    If you want to avoid a ticket during a tag mis-read, you should. If you have online account access you can do it there.
  3. SureValla
    SureValla Member
    590
    Shelton, CT
    <div class='quotetop'>QUOTE(Fred S @ Aug 30 2007, 09:28 PM) [snapback]504632[/snapback]</div>
    really? I checked for it and didnt see that option to change plate numbers
  4. Stev0
    7,201
    1,073
    Northampton, MA
    2022 Prius Prime
    <div class='quotetop'>QUOTE(SureValla @ Aug 30 2007, 08:36 PM) [snapback]504634[/snapback]</div>
    I changed my plates, forgot to tell them, went through EZ-Pass, got a nasty letter from them. I called them, they straightened everything out, but in retrospect I should have called them first.
  5. SureValla
    SureValla Member
    590
    Shelton, CT
    <div class='quotetop'>QUOTE(Stev0 @ Aug 30 2007, 09:45 PM) [snapback]504640[/snapback]</div>
    ok great thanks for the advice
  6. Trevor
    Trevor Member
    352
    Staten Island, NY
    I also got a letter threatening a fine when I got new plates. The EZ-Pass web site (at least the NY version) is pretty useless and I get errors most of the time when I try to change something. I ended up going to the nearest service center and they handled everything.
  7. geodosch
    geodosch Member
    182
    27
    New Jersey, USA
    2013 Prius Plug-in
    On the NY E-ZPass site, it's easy to change your plates or vehicle information:
    Log on to your account using the "Check Your Account" link on the left
    Click on "Vehicle/Tag Maintenance" on the purple menu bar.
    Click on "Vehicle Maintenance" on the sub-menu
    You should see a list of your vehicles
    Click on the plate number in the first column, and you'll get to a maintenance screen where you can change the plate number, vehicle description, etc.
    I've never had a problem using their Web site (I use Firefox)
  8. bc104
    bc104 Junior Member
    57
    New York
    If you don't have it already, ask for the NY Green program and save 10% on tolls as well!
  9. darlenegalik
    darlenegalik New Member
    30
    <div class='quotetop'>QUOTE(bc104 @ Aug 31 2007, 08:43 AM) [snapback]504826[/snapback]</div>
    Is there anything like that for NJ ? Aside from being able to drive alone in the HOV line of the NJ Turnpike, any other hybrid perks ? I have ez pass as well -
  10. PaPrius
    PaPrius Member
    132
    <div class='quotetop'>QUOTE(PriusGirlNJ @ Aug 31 2007, 09:08 AM) [snapback]504832[/snapback]</div>
    I believe driving in the HOV lanes between exits 11 and 14 of the NJT is the only hybrid perk available in NJ.
    As for E-ZPass discounts, there are a bunch, but they generally are based upon the agency through which you have your E-ZPass. The below link should take you to a page that has hyperlinks to a number of the E-ZPass discounts available in and around NJ.
    E-ZPass Discount Plans
  11. geodosch
    geodosch Member
    182
    27
    New Jersey, USA
    2013 Prius Plug-in
    I wondered the same thing, but didn't see anything on the E-ZPass or NJTP sites. So I sent them a message asking if they participate in the Green program.
  12. geodosch
    geodosch Member
    182
    27
    New Jersey, USA
    2013 Prius Plug-in
    Oh well, I guess not. Here is the response from the NJ Turnpike Authority (which also includes the GPS):
