FAA warns of ongoing GPS issues in southeastern US due to Defense Department 'tests'
Discussion in 'Fred's House of Pancakes' started by cwerdna, Jan 20, 2011.
  1. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    FAA warns of ongoing GPS issues in southeastern US due to Defense Department 'tests' -- Engadget
    It might be interesting to see if we get a spike in GPS inaccuracy complaints here on PC during the above time period from those in the affected areas...
  2. a_gray_prius
    2,927
    782
    IL
    Does this mean we should expect more mass bird die-offs?
  3. cit1991
    cit1991 New Member
    289
    95
    Tulsa, OK
    The DOD can encrypt GPS so non-military receivers will not work or work with reduced accuracy. They call it Selective Availability.
    It used to be that we civilians always got reduced accuracy. Then in 2000, they shared the good stuff with us.
    They can still shut it off though (by region). That's probably what they're testing.
  4. fuzzy1
    10,167
    Encryption and Selective Availability are different, unrelated issues. The best stuff is always encrypted and not available to civilians, even when Selective Availability is turned off.
  5. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Only the ones that depend on GPS for navigation.
  6. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    Hmmm...maybe so, but this just sounds "suspect" to me. For GPS not to work, satellite transponders would have to be turned off. If GPS isn't working, then cell phones would be disrupted also. Now, I could see "solar storms" or even a high concentration of radiation (from a nuclear weapon) causing some communication distortion. Nope, not buying the GPS disruption; not just yet. Although, I once "tested" my electrical circuit breaker and took down an entire wall of outlets!
    Happy Motoring,
    Tom
  7. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    There are several ways to make the GPS system not work of work inaccurately without taking down transponders.
    And the cell phone relationship? Other than not being able to use your phone as a navigation device or having your phone tattle on where you are, please explain.
  8. twittel
    1,605
    148
    Mt. Pleasant, SC
    I'm thinking of satellite cell phones that share communication space with transponders rather than cells that use towers.
    Happy Motoring,
    Tom
  9. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Hobbyists and businesses have built self guiding model airplanes that can navigate along a path to a target using GPS.:eek:
    It would be wise to have a means of disabling GPS in a limited region on very short notice. If I had to make I bet on what the GPS test is all about, I would say it's a test of such a rapid response system.:cheer2:
  10. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    The GPS sats are completely independent of the cell phone sats.
  11. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    The precise location and general nature of the announcement makes it sound like an jamming or L-Band radar test of some sort. Most of the significant tests of this nature are done offshore on a barge or ship to get away from any land interference. The GPS signal is rather weak and it does not take much interference of the right sort to cause dropouts on receivers in close proximity. There was no mention of the signals being incorrect, just unavailable, quite a big difference.
  12. rpeeples
    rpeeples Experienced Toyota Owner
    109
    America's own third-world country
    It all sounds like a load of hooey to me. Since a lot of things depend on GPS now, it would not make since for it to be disrupted. I mean, airplanes, law enforcement, emergency response vehicles, farm equipment, ships, etc. depend on GPS.
    I just have my extreme doubts that this is true. It also seems that if it were true, they would give everyone plenty of notice and it would be announced many times by the news.
  13. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Doh! Several of us should have been suspicious and checked it out.
    I went to the FAA website and checked their NOTAMs, not a single mention of the rumored event.
    Thanks for the reality check:rockon:
  14. cwerdna
    12,544
    2,123
    SF Bay Area, CA
  15. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
  16. fuzzy1
    10,167
    I'm not an airman, but what is this FAA page? Ten items, half mention the very same longitude-latitude as the Engadet map, the other half mention a location over southeast California. Distances and flight levels also match up.
  17. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    The western location is a ways northeast of the center of the China Lake Naval Weapons Center on Google maps.
  18. amm0bob
    amm0bob Permanently Junior...
    7,730
    2,547
    This is only a test... :D
