Factory Connect Camera System for 2013 Toyota Prius C with 6.1" Screen
Discussion in 'Prius c Accessories and Modifications' started by priusCpilot, Dec 21, 2012.
  1. priusCpilot
    priusCpilot Active Member
    631
    208
    LA
    Has anyone seen this or used it? What do you guys think?
  2. KaliforniaKid
    KaliforniaKid 2013 Prius v Five 2012 Priuc c Four
    184
    63
    Nuthern Kalifornia
    2015 Prius c
    Thanks for the find.
    Looks like a no-fuss plug and play system (no wires to cut).
    I'm going to contact the vendor for the installation instructions and see where that goes.
    From the vendor's website it looks like the Head Unit is on Bluetooth to Bing's maps - is that what Bing Maps really looks like on the C? 1/3 screen for the map & 2/3 screen for text? Sucks.
  3. KaliforniaKid
    184
    63
    Nuthern Kalifornia
    2015 Prius c
  4. priusCpilot
    631
    208
    LA
    That 1/3 screen map is for selecting which POI you want guidance to. Once you select then it's a full map.
    Are you in So Cal? If so would love to meet up with you when you do the install and check out how its done and help if I can. I also am interested in getting one.
  5. KaliforniaKid
    184
    63
    Nuthern Kalifornia
    2015 Prius c
    I'm in Brentwood, not the SoCal community but the City in the San Francisco East Bay.
    I was going to spend some dollars stiffening the chasis but the rear view camera is a priority for me.
    My rear glass is tinted at 5% and I can't see what's back there unless I stick my head out the window.
  6. priusCpilot
    631
    208
    LA
    Haha me too! I wanted to get all the Cusco goodies!
    Can you post about the install here and take some pics maybe? Any pointers would be great! Thanks!
  7. Hemy03
    Hemy03 The Flea. Work in progress.
    28
    Yeah please keep me posted. I did the DIY from scratch install kit and it only worked on occasion and very randomly. Not sure why
    rms015 likes this.
  8. KaliforniaKid
    184
    63
    Nuthern Kalifornia
    2015 Prius c
    OK - unit installed by professionals (too bone tired from spending a week at Disneyland chasing the kids & waiting in lines). Sorry, I should have taken a picture of the kit's contents but below is a copy of the installation sheet.
    It is a "plug & play" installation as there is a T-Harness to plug in place of the Head Unit's factory 16 pin plug. It accepts the camera's RCA plug and the existing factory 16 pin plug. I instructed the shop to be sure to use a 12V source for the camera as the Head Unit is only 6V and to not configure the parking lines (green wire). I also instructed the shop to install the camera to the left of license plate where there is a small square outlined just left of the license plate light. The kit came with a 19mm drill bit for the camera.
    The camera works well. Whatever is on display on your NAVI screen goes to the view from the camera when you shift to Reverse and when you shift out of Reverse the NAVI screen returns to whatever was on previously. The image is clear with a very slight fisheye effect. Worked well in a dark garage too.
    My suggestion is to not utilize the parking lines in favor of an un-obstructed rear view.
    Camera is mounted to the left of the license plate.
    Very clear color image - IMHO.
    Instruction sheet - looks like a Corolla's hatch.
    ChinchillaGirl and ftl like this.
  9. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Thanks for the follow-up! What was the installation cost, if you don't mind saying?
  10. KaliforniaKid
    184
    63
    Nuthern Kalifornia
    2015 Prius c
    $170 Best Guys, Concord, CA
    2 hour install at $85/hour.
  11. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    How do you cut to install the camera on the license plate cover above?
    Can you post close up pic of the camera?
  12. priusCpilot
    631
    208
    LA
    Cool stuff! Looks perfect! Two hours install sounds good? So you don't have to remove the carpet and all the seats to run the wires?
  13. KaliforniaKid
    184
    63
    Nuthern Kalifornia
    2015 Prius c
    Here's a photo of the camera installed to the left of the license plate light on the underside of the liftgate's bezel. The kit included a 19mm drill bit for the camera's mount and cable which is fed through the hollow liftgate and into the existing wire loom entering the vehicle (see photo). The cable is fed through the roof's headliner, down the A-Pillar, across the dash and into the NAVI.
    Camera on underside of liftgate bezel.
    Camera cable from hollow of liftgate with loom of existing wires into interior of vehicle.
  14. priusCpilot
    631
    208
    LA
    Never done wiring work before so wounder how easy it is to feed it through the head liner to the dash?
  15. Arin Artounian
    Arin Artounian Junior Member
    maybe a dumb question but will this not work for a 2012 prius c 4?
  16. KaliforniaKid
    184
    63
    Nuthern Kalifornia
    2015 Prius c
    The camera was installed on my 2012 C4 - I know, the ads say "2013".
    Is the 2013 model out in the dealerships yet?
    I've read the base 2013 will be going for $130 more than the 2012.
    I've also read the 2013 will come with the center chassis brace installed as in the Yaris coupe.
  17. Arin Artounian
    Thanks I should have bothered looking at your profile.. new to forum.
  18. priusCpilot
    631
    208
    LA
    If they did install the brace I doubt it will be from aluminum like the Cusco.
  19. ChinchillaGirl
    ChinchillaGirl OrcaCar
    157
    72
    SJ/SC Commuter
    My SO and I spent the afternoon installing this kit ourselves (2012 C4), but used Mik's installation procedure for wiring from front to back under dash to driver's side doorsills into trunk, then up under rubber gasket into hatch). It was nearly plug-n-play at the head unit end, and most of the time was spent routing the wires.
    There were a few surprises not covered by vendor's installation instructions (not written for Pruis c!). Job took 4 1/2 hours, but we were being very careful!
    The addition is a success- its hooked up, goes on in reverse and shows on Nav screen! The default wire set-up gave me guidelines (which I kept, but if you connect the green, they would go away), but we needed to "program" the reverse image by connecting the white wires' option because the image was upside down by default.
    Its wonderful!!!!
    Rainking likes this.
  20. HOG-Rules
    HOG-Rules New Member
    Hello everyone
    I purchased this kit off ebay with no instructions. I see KaliforniaKid posted them anlog with some pics. Thanks
    I have been reading Mik's thread and will be following his method for routing wires as I will also be installing foglights
    Toyota of McDonough Parts — 00016-47160 Toyota Prius C Fog Light Kit
    My question is for ChinchillaGirl or anyone who has the answer.
    Where did you connect the 12v and ground for the camera kit above?
    HOG-rules
