Factory EV Button Confusion
Discussion in 'Gen 2 Prius Accessories & Modifications' started by DanCole42, May 2, 2005.
  1. DanCole42
    DanCole42 New Member
    24
    Arlington, VA
    So I read the Factory EV Button Install, but there's one thing it doesn't make clear - I'm hoping someone can help.
    On the factory EV button are four metal contacts that are supposed to plug into the homemade wiring harness. My question is, from the top of the switch to the bottom, which one goes to what? I.e. which contact goes to the ECU, which goes to the ground, etc.?
    Thanks!
  2. finiyon
    finiyon Re-Member
    66
    Philly, PA
    If you get it wrong, you will have my avatar. :oops: Other than the total humiliation, no other damage was done.
  3. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    I double checked to make sure it's there (given that I wrote it... )... it is. About 1/2 way down, I list the pinouts.
    I believe the numbers were stamped into the plastic. If not, use a multimeter or continutity tester at low voltage to discern the two. Good luck!
