Factory NAV dashboard fit
Discussion in 'Gen 3 Prius Audio and Electronics' started by web1b, Sep 13, 2011.
  1. web1b
    web1b Active Member
    817
    52
    I noticed the upper left corner is sunken in around 1/4" or more so the system is not flush with level of the surrounding panel trim in that spot. The other three corners look close to flush fitting. Looks a bit sloppy like that.
    Is it normal to be that way?
  2. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    Nooooo, not normal. Trip to the dealer for you. Post a pic
  3. web1b
    web1b Active Member
    817
    52
    Here is a picture. I wish I noticed it when before I had the dealer do the 20K service a few days ago. It isn't worth going back for something this minor. I'll try to remember it at the 30K service unless another issue comes up before then.
      File size:
      78.7 KB
      487
  4. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    hmmmmmmmm
