Factory PHEV - WAY under $42,000
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by hill, Mar 21, 2011.
  1. hill
    8,177
    I give you - "The Leaf PHEV"
    pEEf posted this on another forum . . . and I couldn't help but admit, "I knew THAT wouldn't take long":
    There have already been several generator trailers created for EV's ... and pulled along behind their ride. So ... why not?
  2. UsedToLoveCars
    UsedToLoveCars Active Member
    448
    102
    surprised someone hasn't built one of these for their Leaf, yet...
    BTW - would this skirt CARB and EPA emission laws?
  3. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    The Honda EU2000 is rated at 2000 watts, and claims 9.6 hours on 1 gallon of gas (at rated power?). The Leaf claims 34 kWh / 100 miles.
    So:
    A 1 hour charge would get you 5.8 miles.
    A tank (1 gal?) would get you 56.4 miles.
    Running the generator while driving (NOT RECOMMENDED!) would allow you 5.8 mph sustained.
    Interesting.
  4. Skoorbmax
    Skoorbmax Senior Member
    2,641
    264
    Western NY
    DO NOT want to be in that yellow car in an accident.
    I imagine these generators cannot produce the watts needed unless quite large.
  5. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    Somewhere in my past posts about a year ago, I suggested this several times. I think it's a brilliant idea. I would say it's just a matter of time before one of the major automakers, such as Nissan, starts making a generator like this and marketing it specifically for hybrid cars. Perhaps a 15 minute "quickie" charger to get you five miles to the nearest charging station or power plug.
    If you've ever run out of gasoline two miles away from the nearest gas station (I did once when I first started driving many years ago), then you know that 5.8mph is golden compared to alternatives (walking, pushing, waiting 40min for AAA to show up).
    Did any of you think of having a friend push the car up to 10mph, hopping in, shifting to neutral, then using regen brakes on the downhill section and at the stop light? Duh! :D We didn't have regen when I was a kid!!!
    Let's see how long it takes before Honda starts taking credit for this. :rolleyes:
  6. austingreen
    austingreen Senior Member
    13,574
    4,114
    Austin, TX, USA
    I'm sure Nissan thought of this, but there is one big problem CARB. I'm sure if a car vendor sold this on an BEV, CARB would require a catalytic converter and 15 year warranty on emissions control.
    A removable generator is a great idea, but I doubt we will see them in the united states except as kits.
  7. Corwyn
    2,171
    659
    23
    Maine
    Ah, I should have been clearer. Running a generator inside the cabin while you are driving is not recommended due to fume issues.
  8. cproaudio
    cproaudio Speedlock Overrider
    2,401
    759
    CA
    Don't knock the T-Zero. At it's introduction, it's the fastest electric car ever build. It's built like a race car. Trailer generator is nothing new.
    Rav Long Ranger
  9. ken1784
    ken1784 SuperMID designer
    2,940
    1,365
    67
    Yokohama, JAPAN
    JP Nissan Leaf users manual states do not use any generator.
    It is designed to charge the battery using grid electricity.
    Ken@Japan
  10. hill
    8,177
    Ken - I had to smile, thinking about manufacturers "do not" warnings. I immediately thought of your post here:
    http://priuschat.com/forums/gen-ii-prius-modifications/36342-another-thermistor-hack.html
    :p
    Most of the mods we do, are things that the manufacturer frown on. But ... if we listened to the manufacturer ... we might still be waiting for them to invent a PHEV ... or maybe they'd still be saying, "nobody wants one".
    3 people like this.
  11. ken1784
    2,940
    1,365
    67
    Yokohama, JAPAN
    So, charge your Leaf by generator at your own risk.
    I'm curious how US Leaf users manual states about this.
    Ken@Japan
  12. caffeinekid
    caffeinekid Duct Tape Extraordinaire
    334
    44
    Houston
    Well, it can be referenced here: 2011 Nissan Leaf , but I haven't seen anything about it. As a general rule, I never liked powering complex power electronics with generator current without some sort of decent filtration/conditioning.
  13. hill
    8,177
    Common sense says Nissan would find it voidable, however, this is all I could find in the manual ... without any more specificity:
  14. ken1784
    2,940
    1,365
    67
    Yokohama, JAPAN
    Thank you for the manual link, caffeinekid.
    Code:
    Only charge using a standard 110 -120 volt, 20A dedicated electrical
    outlet (For example do not use an electric generator). Failure to do so
    may cause charging to fail and could cause damage to the Li-ion battery
    charging equipment due to power surges.
    It is almost same as JP's.
    Ken@Japan
  15. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    34kWh/100 miles includes aggressive high speed driving. Local driving consumes only 20kWh/100 miles (200 Wh/mile). Dave has done it with his Leaf.
    EU3000IS generator should be able to run the Leaf at 15 mph (@200Wh/Mile). The generator is under $2,000.
  16. Flying White Dutchman
    4,374
    313
    i think leaf warning is for old generators
    newer ones have a better sine(cleaner)wave.
    and if power surgers can also happen on grid i think the charger wil be damaged if any and not the battery pack.
  17. cproaudio
    2,401
    759
    CA
    I think for generators to be effective, it needs to bypass the charging circuit and go directly to the battery or the motor with DC output to achieve sustained city speed at the least. The extended range RAV4 EV uses 20kw DC output to allow the RAV4 to travel at highway speed.
  18. drash
    drash Senior Member
    2,483
    1,256
    Upstate NY
    And how long before some organization like AAA adds this to their "services" although it will probably be like a rather large diesel generator that puts out 240V.
  19. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    I'm not surprised. I've always heard the output from generators is pretty dirty. I also am unsure if some of them don't put out a pure sine wave and thus could cause other issues.
    Also, at the Nissan Leaf events, they mentioned that you can't drive off if still plugged in. This is confirmed by the manual which says:
  20. cwerdna
    12,544
    2,123
    SF Bay Area, CA
