Factory Prime Charge Cord Length
Discussion in 'Prime Main Forum (2017-2022)' started by Steve C, Oct 26, 2017.
  1. Steve C
    Steve C Junior Member
    Wisconsin
    2001 Prius
    I searched this Forum and the owners manual. My 2017 Prius Prime will arrive in about a month. I am researching L2 charging but was curious how long the actual factory provided L1 charge cable actually is. Current Prime owners? Can you help me out please? Thanks!
  2. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    25', and I occasionally use a 25' 12-gauge extension when needed! I've had the extension since my 2012 PIP.
    priuscatprimeguy likes this.
  3. PT Guy
    PT Guy Senior Member
    1,085
    712
    Washington, the state
    I figure that a full battery charge saves me about a buck's worth of gasoline. An L2 charging station, even when competently self installed, will never pay off. Buy one for philosophical reasons if you wish, not economic reasons.
    mmmodem likes this.
  4. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Ditto above. I've been charging with supplied cord for over 5 years.
    Sister has a Leaf and a Volt. She charges both with the supplied cords, no L2. Leaf rarely gets driven further than 50 miles due to range anxiety. Thus an over night charge will be enough to full. The Volt gets charged the other half of the day. Works beautifully.
  5. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    Mr. PT,
    My L2 charger, installed including parts and labor, cost me $100.!! It has more than paid for itself in the 3 1/2 years that I've had it. Please check your LOCAL agencies for incentives (mine was $1000 cash!) before giving up on L2. I typically charge 2-3 times/day.
    In Socal, they really encourage electrification of cars!!
  6. alexcue
    alexcue Active Member
    346
    311
    So Cal
    I bought an L2 because LADWP basically paid for the charger and I only had to deal with the install. I overbought and installed a 40A L2. Well, switch over 5 months and my honey just picked up a Chevy Bolt. While the maximum time it took me to charge my Prime is about 1:52 (assuming I didn't use the Cooling function). It can handle her dead flat Bolt in just over 9hrs. So in my case it paid off to plan ahead. If she was to use an L1 charger it would take like 50+ hours to charge.
