Factory XM Kit antenna question
Discussion in 'Gen 2 Prius Audio and Electronics' started by adegiulio, Jul 16, 2007.
  1. adegiulio
    adegiulio Junior Member
    Red Hook NY
    A couple of months ago I installed the XM tuner kit. It was a nice easy install, and as per the directions, I placed the antenna up near the front of the dashboard. Well, as some of you know, the reception isn't too great, and I would like to install the antenna on the roof. My question is, can I install the antenna that came with the kit, or do I need a different, more weatherproof, antenna?
    Thanks for any help
  2. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    The same antenna can be mounted outside the car, Others here will tell you how.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    [​IMG] A great way to do it (albeit with a mild loss of signal) is to buy one of the shark fin antennas (sold in the Priuschat shop), run the wire through the hole where then existing radio antenna whip is, then hide the XM antenna under the shark fin.
  4. b777
    b777 New Member
    24
    I have a 2007 Camry Hybrid with XM and a 2007 Prius with XM that I installed and there is no difference in reception. I personally like the antenna on the dash, but make sure it does not touch the window. The Camry's antenna is located in the back window area inside also.
  5. BethlehemPrius
    BethlehemPrius New Member
    180
    Bethlehem, PA
    As the others have stated you can use the same antenna. If you don't want to buy a shark fin antenna, which I don't think they pick up FM to well, but guess its not an issue with getting satellite. However, as I was saying you can just put the antenna on the roof right in front of the rear hatch very easily.
    The person who posted the pics ran it through the headliner which you can do, or run it up around the hatch and place it on the roof in the middle if you don't want the sharkfin.
    hit me up if you have any questions. Good luck.
  6. sagediaz
    sagediaz Guest
    If you replace your FM Antenna with the sharkfin, how is your Fm reception? Does the shark fin somehow have both an FM antenna connection as well as an XM or do I have to choose one over the other? I'd like to replace my magnetic dash mount XM antenna with a permanent roof mount solution however not at the expense of the FM. I wish they came out with a combination XM sharkfin/FM whip antenna. Anyone have any ideas?
  7. BethlehemPrius
    180
    Bethlehem, PA
    <div class='quotetop'>QUOTE(SAGE @ Jul 17 2007, 05:20 AM) [snapback]480128[/snapback]</div>
    Sage,
    The sharkfin antenna is the replacement for the FM antenna on the roof, if you get that antenna it simply sits on top of the xm antenna hiding it. While the xm antenna worked fine under it, I feel that the sharkfin severely cuts down reception of FM stations. While it was not a deal breaker for me, I do like to listen to some local stations for traffic alerts etc, but find that even my station in my home city is no longer that strong of a signal with the FIN style. I live in a hilly area in Eastern PA so am thinking that is my cause as some claim the FIN works fine for them.
    Anyways, thats my two cents. good luck :)
  8. Elephanthead
    Elephanthead Junior Member
    72
    I see people running it u through the hatch and sticking it on the roof, its not hidden, but that has to be the best spot, I was thinking of intergrating it into my spoiler, but it would look ganked up, so I didnt do anything. Its black, I don't see why you can't put it in the hood cowl somewhere.
  9. rsvogt
    rsvogt New Member
    I had the Soundlinq2 SL2x XM interface installed in my new 2007 and I could not fine the antenna. After checking with the installer I found he had installed it under the dash. I can tell you it works perfectly. The installer claimed that with the sloped windshield it would not be a problem. Nothing to see at all - just listen to XM.
