Failed battery, putting gen 3 cells instead of gen 2?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by McNuilty, Apr 4, 2018.
  1. McNuilty
    McNuilty Junior Member
    24
    Netherlands
    Business Edition
    Hello
    Last week my hybrid battery failed again after 5 months and 10.000km since my last repair (just swapped 2 modules). My car; 2006 prius with 265.000 km on it.
    I'm now looking at my options. Don't feel like changing the 1 or 2 modules again as its alot of work and uncertain drive. Seems like it's no permanent solution. As this is my only car I want it to be reliable.
    My options are:
    - buying a 2006 used battery with 170.000 km on it from scrapyard (500 eu)
    - buying a 2008 used battery with 240.000 km on it from scrapyard (550 eu)
    - buying a 2010 gen 3 used battery from scrapyard with low mileage (around 50.000 km) and swapping all of my current cells (550 euro)
    + selling old battery/cells for around 100 euro?
    - Buying new battery from toyota dealer, around 1800 euro fitted, Toyota will keep my failed battery.
    As it's likely that the gen 2 used battery's from the scrapyard will fail in the near future I'm thinking to put a new battery or put gen 3 prius cells.
    I've read on this forum how it's possible to change all gen 2 cells with gen 3 cells. Is this fairly simple to do? I did the swap of the gen 2 prius cells with no problems.
    Can anyone give me information about putting gen 3 battery cells in a gen 2 prius?
  2. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Out of those options, the only one that makes sense is the new battery. For $2200/€1800 installed, go for it if you plan on keeping the car. As you learned with the replacement modules, it is a game of whack-a-mole and another just popped up.
    If you were doing a repair that didn't require a core charge you can get a lot more than €100 for the battery you have now. You should have 1 maybe 2 bad modules. Those go for about $10 used. With a proper power supply and some balancing and work on your end you can condition the other say 26 modules and sell them for $20 to $30 all day long. If we take the low end estimates of $540 in recouped battery costs minus 25% for eBay fees, PayPal fees, shipping fees, etc that's $390 or €320.
  3. priusb78
    priusb78 Member
    66
    50
    Nuremberg, Germany
    SFO likes this.
    51,155
    i vote gen 3 modules if you're comfortable that the age and km are correct. should get a few years out of it.
    how long do you plan to keep your car?
    SFO likes this.
  5. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    The 2010 is already 8 years old... These are not new vehicles anymore and that pack is going to fail sooner than later.
  6. bisco
    51,155
    agreed, that's why remaining ownership is important.
  7. McNuilty
    24
    Netherlands
    Business Edition
    I
    Can get a 2016 gen 4 prius battery with 10.000 km atm.
    If it isn't a plug in should fit just like gen 3 cells?
    If so Ill just go for tht option if I can get it for a nice price.
  8. McNuilty
    24
    Netherlands
    Business Edition
    As long as affordable, I drive 35.000 km a yr so I hope atleast 2 or 3 yrs.
    But would certainly buy another prius after this one.
  9. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Completely different animal, no it won't work.
    2015 Gen3 is the latest you can get. And that's why you CANT. Because everyone else that does it for a living scoops them up for rebuilds of 2001-2015 Prius packs.
  10. McNuilty
    24
    Netherlands
    Business Edition
    I'm a little confused now, why was priusb78 able to do it?
    Also for gen 3: I can't put prius plus modules I suppose? Just regular Gen 3 till yr 2015 non plug in?
  11. dolj
    dolj Senior Member
    8,217
    4,187
    Wellington, New Zealand
    In the Gen 4, there are NiMH modules in the two lowest trims and LI-Ion modules in the all the other trims.
    You can use the Gen 4 NiMH, but not the LI-Ion modules for rebuilds of 2001-2015 battery packs. Visually, the Li-Ion look quite different, so you shouldn't mistake them for NiMH.
    #11 dolj, Apr 5, 2018
    jerrymildred and SFO like this.
  12. McNuilty
    24
    Netherlands
    Business Edition
    Ah that explains.
    I'll be looking for a regular gen 3 prius battery.
    Not plus or plug in.
    Anything else i should look at when buying the gen 3 battery?
  13. Prodigyplace
    12,407
    11,682
    Central Virginia
    That is true for the US. I do not know what batteries are used for Gen 4 in the Netherlands.
  14. priusb78
    priusb78 Member
    66
    50
    Nuremberg, Germany
  15. Prodigyplace
    12,407
    11,682
    Central Virginia
    A couple of people here have built Gen 2 pcks with Gen 4 modules. It is never recommended to mix generations in the same pack.
    Toyota says the Gen 4 use a higher quality Nickel in the batteries.
    jerrymildred likes this.
  16. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    Plenty of good advice here already. And maybe a little confusion here and there, which is understandable given how many variations there are.
    Gen 3 or Gen 4 NiMh cells work fine. My wife has cells from a 2015 in her 2007. I don't think I would want 2010 cells, though because they are getting too close to the end of their life for the expense and work involved. As previously mentioned, be sure to replace them all.
    If I was sure I would keep it for a long, long time, I'd get a new battery. But that's a bit of a gamble what with the possibility of brake accumulator and air conditioner failures when they get this old.
    Prodigyplace likes this.
  17. Figster10
    Figster10 Member
    207
    61
    Sacramento
    So, after reading this entire post thread is it safe to assume you can cross gen 2 and gen 3 cells when doing repairs? I am asking because I was buying used cells from a yard and the guy told me gen 2 and gen 3 are the same or can work for repairs. I didn't see any issues once I did the repair but I'm wondering if this has ever been a bad idea. I'm talking about just gen 2 and gen 3 even though I know everyone has their own opinions. Plan on keeping car for a year before I sell it.
    Cars: Gen 2 and Gen 3 prius
    Concern: using cells from either of the two generations to do repairs 2004-2015 hybrid battery cells. Is there going to be an issue?
    Reason: I want to do repairs on future cars with the same cells. I don't plan on buying new batteries for these cars so please spare me the advice to buy new.
  18. dolj
    dolj Senior Member
    8,217
    4,187
    The generalisation for the advice is around the fact that modules from a Gen 3 are going to be newer than the modules from a Gen 2.
    The concern around that is you don't want to be mixing modules with a higher capacity with modules that have a lower capacity, that is just asking for trouble. Your aim is to match capacity like for like. If your Gen 3 modules match closely with your Gen 2 modules, it will most likely work ok.
    jerrymildred and Raytheeagle like this.
  19. jerrymildred
    11,517
    14,137
    Tampa, FL
    The most successful and long lasting method would be to replace all the cells at once with a set from a newer battery. As @dolj said, mixing ages can lead to earlier problems down the road. Internal resistances change with time and you want them all to be as nearly equal as reasonably possible.
    Neural Net and Prodigyplace like this.
  20. Prodigyplace
    12,407
    11,682
    Central Virginia
    Gen 4 NiMH modules would work too but most of the US models use a Li-Ion battery pack.
