Failing Garage Remote
Discussion in 'Gen 2 Prius Main Forum' started by Palmetto, Mar 21, 2009.
  1. Palmetto
    Palmetto Junior Member
    88
    West Michigan
    My 2008 used to be able to open the garage door from 2 houses away.
    Now, I must be sitting immediately in front of the garage door for it to work, and even then, I press 5 or 6 times before the door raises. This has been going on for several days now.
    Does my car need warranty service or is this something easy I'm overlooking?
  2. EZW1
    EZW1 Active Member
    722
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Could be Homelink dying or your opener dying. Can you try one of your opener clickers and see if they work any better?
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    It could be stray radio signals in the area. I've had it happen to me on occasion with my 04 and 09.
  4. Palmetto
    88
    West Michigan
    EZW1, I will dig out the opener when I can remember where the heck I stored it. My wife has not had trouble using the homelink equivalent in our Acura, so I'm going with dying homelink for now. I was posting to make sure it was nothing easy I was overlooking to figure this out. Thanks-
  5. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    My Homelink is also hit-n-miss sometimes.
  6. Palmetto
    88
    West Michigan
    Tony,
    Did you have your homelink serviced or are you just living with it?
  7. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    Did you try reprogramming the unit? Not sure if over time, any rolling codes may be slightly out of sync requiring more "time", but could really just be the transmitter. I've noted the range on my Homelink device has never been as good as the opener's transmitter, nor as quick (takes 0.75-1.0 sec on Homelink vs. instant w/ OEM opener).
  8. Palmetto
    88
    West Michigan
    Good idea about reprogramming the homelink. I will try this before I schedule service. Thanks!
  9. EZW1
    EZW1 Active Member
    722
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Same here. I just blow it off to the opener.
  10. oxnardprof
    oxnardprof Member
    249
    17
    Oxnard, CA
    Could this be a warning sign of weakness in the 12V battery?
    I had one instance recently when the homelink failed to open the garage door. Later, it worked just fine. I am planning to change the 12V battery soon, as it is almost 5 years old, and I want to avoid a battery failure.
  11. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    It shouldn't be, assuming the Inverter is doing its job powering the 12V bus.
    Tom
  12. yatbiz
    yatbiz Junior Member
    los angeles
    my homelink has never worked my bad
