Failure of Air Conditioner Compressor Due to Lack of Maintenance?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Pandas Andpresents, Jun 30, 2021.
  1. Pandas Andpresents
    Pandas Andpresents Junior Member
    34
    Danbury, CT
    Hi everyone,
    I have a 2011 Prius with 135,000 miles.
    My a/c stopped working over the weekend. I took the car to a dealership on Monday. They said that the a/c compressor needs to be replaced. The cost that they quoted is 1.3K, which seems typical having read Prius Chat posts about this. I also called around and the 1.3K was by far the cheapest price for a/c compressor replacement in this area.
    What are the typical causes for a/c compressor failure? I came across a YouTube video in which a Prius mechanic said it's typically an a/c maintenance issue. Just wondering if I missed recommended maintenance on the a/c system?
    Also, sounds paranoid, but could this be caused by vandalism? (One of our neighbors was road raging the other day and my boyfriend got into it with him. It's kind of a coincidence that the a/c went out just ahead of a string of near 100 degree days in the Northeast.) Is the compressor located in a place that makes it easy to vandalize?
    Could it be something less involved and expensive than replacing the compressor? The dealership said the compressor is the code coming up when they run the car. They said that the coolant looked "just a bit low", so they tried adjusting that first, but it didn't work.
    Thanks for reading and any information!
    49,374
    i don't think so. not much talk about a/c maintenance around here, and very few gen3 bad compressors.
    we do see one once in awhile, and i suspect it is simply manufacturing tolerances. or maybe i should say intolerances.
    if you notice a decline in cooling, but fail to take action, that could be a problem, idk.
    not likely vandalism, and $1,300. is a good price i think. you can always get a second opinion.
    did you pay for the diagnosis? ask for a printout of the codes
    Pandas Andpresents likes this.
  3. Grit
    Grit Senior Member
    6,139
    4,053
    Wilkes Land
    cant rule that out just yet. Some feller had his wiper blades assembly stolen. And if you drive a Prius and go all road ragging, other drivers will love you even more. Even after incidents.
  4. Pandas Andpresents
    34
    Danbury, CT
    Okay, thank you for the reply and the information. I really appreciate it!
    The dealership took a "diagnostic fee" for the diagnosis but they said they would apply it to the cost of the repair if we choose to have it done there. The $1300 is exclusive of the diagnostic fee.
    The code provided is B1476. Does this correspond with the compressor being shot? (I Googled and I am finding "a/c compressor inverter load system malfunction"? Probably unrelated, but we were having power issues with the car during the colder weather. It wasn't turning on with one press of the power button. We chalked it up to battery issues.)
  5. Pandas Andpresents
    34
    Danbury, CT
    Is the a/c compressor easy to get to though?
    Priuses sit low to the ground to begin with and then, IIRC, there is a cover under at least some of the underside of the front of the car - is this correct?
  6. Pandas Andpresents
    34
    Danbury, CT
  7. ChapmanF
    15,435
    The code means that powering the compressor is taking either more or less electrical power than it ought to for the compressor speed in question.
    That can mean that the compressor is shot, but the repair manual's got a small three-page section of things worth checking before going straight for that conclusion.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    The thing that can harm the compressor is a very clogged condenser coil.
    Makes the compressor hot.
    On G2 Prius quite easy to see condenser you take off the the plastic rad cover not sure If you can on a g3.
    So look carefully through the front grill for the condition of the condenser. It looks like a radiator it sits in front of the rad. Should look very clean.It requires periodic cleaning just like your home ac. Home ac is a lot of work. The outside condenser coils need to be cleaned and the inside air handler evap coils need to be cleaned too.
    And in a car the evap coil in the dash needs to be serviced too use Kool It
    cleaner.
    and lastly its crazy to take your car ac work to a dealer. There like $175 an hour. Find a local ac company a Prius is a very common car now.
    the fact that there condemning the compressor may mean the system has had a slow leak all along and running the compressor a long time with low charge will ruin it.
    so the question is has the ac been poor for a while? Not super cool?
    It should be freezing.
    If poor ac that’s a big problem because it had a leak it killed the compressor and now you don’t know where the leak is hope it’s not the evap box under the dash like mine. The dealer will kill you with the bill. That will be $2500 by the time there done if evap leak.
    The problem is you need a new compressor for them to charge it dye it and find a leak if any. And it probably has a leak.
    Financially it’s quite the roll of the dice sorry…..
    Tboy160 and Pandas Andpresents like this.
  9. Mendel Leisk
    38,647
    One cause, and it’s a bit of a sand-pounder: there’s a 12 volt connector atop the compressor, and it’s a perfect receptical for water, which shorts/corrodes the pins. Repair is nigh impossible; it can toast the compressor.
    Any recent engine bay “detailing”? If yes and it was by the dealership, I’d check that connector personally, take pics, chase them for it.
    as you stand at front of engine bay, compressor is at front/left/lower corner of engine. Relatively easy access once engine intake air snorkel and air filter box are off. Technically just the snorkel needs removal, but it’s kind of hard to separate from air filter box in-place.
  10. edthefox5
    10,096
    4,804
    Clearwater, Florida
    Looked at compressor on line it’s $570. Deakerwill mark that bad boy hard.
    $900.
    take the car to an ac joint.
  11. ChapmanF
    15,435
    MSRP $1486.28 (today). $900 at a dealer would be a very nice markdown.
  12. Pandas Andpresents
    34
    Danbury, CT
    Thank you everyone. I appreciate your willingness to share your time and knowledge!
