False Positive P0A80? - Replace Hybrid Battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DaveW06, Mar 4, 2015.
  1. DaveW06
    DaveW06 New Member
    Chicago
    Hello all,
    Recently my 2nd gen Prius has been acting, strange. I hoping to get some insight to the best way to fix the problem, so I will include as much detail as I can. Please bear with me :)
    Over the weekend I went to go run some errands and while I was leaving my neighborhood, my dash lit up like a Christmas tree, with the red triangle, CEL, low tire pressure, and the exclamation on the MFD. So I quickly turned around and parked it back in my garage.
    A little later and after doing some research on the forum here, I began to troubleshoot, at which point the feeling of dread was at the pit of my stomach and decided to go to the local auto store and have the code read. It was of course the "P0A80 - Replace Hybrid Battery Pack" the exact message I didn't want it to be.
    So I turned around and went back home, the entire time all the lights stayed on and monitored the SOC of the traction battery. It was charging, just increasing and decreasing quicker than usual. (arghh).
    So upon arriving home I started by popping the trunk and with the hope to check the voltage of my AUX battery, upon doing so I noticed that my (aftermarket) Alpine subwoofer amp was on, which it shouldn't have been! So I go ahead and check the switch I installed and sure enough it's on. So now I am thinking, "that might have been the problem!' So I completely disconnect amp from the AUX battery, and disconnect the AUX battery. I check the voltage and it's at 11.1V. So I pull out my batter charger and hook it up. The plan being I'll charge it overnight, take off the charger in the AM and let it sit all day and check the voltage again that evening (10 hours later).
    So I get home that night, hook up the battery and check the voltage via the dash display and they all come in within range. Sweet. And of course since the battery was disconnected all the error codes (lights) on the dash have cleared. So I decide to take it for a spin.
    I drive around for a good 15 minutes, and everything is acting normal, traction battery is charging/discharging normally and no lights come on.
    Now comes yesterday morning and I have decided to take it to work, thinking it was just the AUX battery being low. I start driving, all good. Then I get to a stop light (10 min from home), and as normal the car shuts off, I currently had the following items on; radio, front and rear windshield wipers, rear defroster, heated seat (aftermarket), radar detector, radio and a bluetooth transmitter plugged into my cig lighter. (yea I know). So as I come to the stop, again my entire dash lights up, crap.
    I quickly get in the right turn lane, so I can turn around and notice I have no power! My ICE is completely off and I notice my SOC at two bars and dropping, so I quickly pull over throw the hazards on and turn the car off.
    Crap. So at this point I decide I will turn it back on, if the ICE still stays off I will get a tow, but luckily it turns right on, dash is still lit, but it's driving so I take it back home and park it in the garage.
    Now to last night, I hop back in the vehicle to do some more readings on the AUX battery voltage. The first time I do it, dash warning lights are still on and AUX battery voltages are still in range. Then I do it again, but this time the entire dash is normal, no warnings at all!
    Some details:
    - Unsure of AUX battery age, it is OEM, though.
    - 211,000mi
    - Regular maintenance schedule followed, since I owned it, I am the third owner.
    - Last oil change the tech noted that the coolant pump (? ) was leaking, which upon researching here is normal under most conditions.
    AUX Voltage readings for every "stage" (each were +/- .1 -. 2v):
    ACC - 12.3v
    ACC w/ load - 11.9v
    On - 14.0v
    So I plan on ordering the Optima Yellow top, as I am due for it anyway and everyone here has said that if you even think it needs to be replaced, replace it.
    Thanks again for your time and help.
    -Dave
  2. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    At that age, and that mileage, the default response first step is going to be the advice to replace your aux battery. Which I read you plan to do.
    Then I think you hope it solves your problems.
    It may...or may not. If your Hybrid Battery is failing? It wont. But at least you will have ruled out failing Aux Battery as a decoy culprit. And at that age, you're not wasting money replacing it anyway.
    It's a good first step.
    DaveW06 likes this.
  3. exstudent
    exstudent Senior Member
    2,213
    901
    Torrance, CA
    If your car has SKS (Smart Key System), you really need to get the larger 45 AmpHour battery from the dealer or one from Exide, Bosch.
    The yellow top Optima is 36Amp Hr. Non-SKS cars come equipped w/ 35AmpHr from Toyota.
    Reason for this is the constant drain from the SKS system.
    MidnightSun and DaveW06 like this.
  4. nh7o
    nh7o Off grid since 1980
    1,686
    338
    Hawaii
    The P0A80 DTC is probably the real thing, as low 12V generated errors, while a bit random, tend to cluster more in the brake system. At 211K miles the Hybrid battery has had a good long run. You can try doing the grid tied balancing procedure, if you are a hands on type. Otherwise it is time to start shopping for a replacement.
  5. DaveW06
    DaveW06 New Member
    Chicago
    I do agree with that statement. And I am not looking forward to pulling and testing the cells, which seems to be the most economical choice.
    I guess the only thing throwing me off is when the ICE wouldn't/didn't run, does anyone have any idea if that would be caused by the traction battery failure, or could that maybe point to the coolant pump, or something else?
    I have seen many different options for replacing the traction battery, either entirely, by bad cell, or as nh7o mentioned grid tied balancing (which I need to read up on). If I do decide to pull it out and test each cell, what is the likely hood of needing to do it again very soon (another cell failing)?
    Also if I choose to replace the entire pack, what is the best route to go; used, re-conditioned (?) or new?
    Sorry for all the questions, but I really do appreciate your knowledge and feedback immensely!
    Thanks
    Dave
  6. nh7o
    1,686
    338
    Hawaii
    Getting all codes read would be important at this point. There are too many variables to make an easy choice with this fix: how long will you keep the car? how much can you afford? how long can you be without the car? I would say, if money is not the object, given the age and miles, new is the way to go. Doing a rebuild will lead to a whack-a-mole situation. Check you area to see if there are any well reviewed installers of rebuilt packs. Throw some I Ching coins and make your choice.
    DaveW06 likes this.
  7. DaveW06
    DaveW06 New Member
    Chicago
    OK, so I contacted Steve over at AutoBeYours and picked up a "new" battery from him. Granted it was a 10 hour round trip drive, but in my opinion, well worth the trip, his shop is like a Prius graveyard, with parts and more parts. Honestly it was a lot of fun!
    Anyway got the battery installed yesterday morning, and everything worked great!
    Before the battery was replaced I was pulling around 43mpg/tank, today on the way into work (30mi) I averaged 58! I am very pleased this all worked out with a little elbow grease and much less $$ for a new one ($3,800 from my local dealer).
    Another side note, the AUX battery is a Toyota "Premium" battery or whatever its called, and apparently has very long warranty (7 yr?), unfortunately I have no idea when it was installed. I've looked through the service records online, but could not locate it. Is there anyway to find a manufacturer date on the battery? Or would it be better to take it to Toyota and have it checked?
    Thanks
    Dave
  8. exstudent
    2,213
    901
    Torrance, CA
    DaveW06 likes this.
  9. DaveW06
    DaveW06 New Member
    Chicago
    Good know! Thanks
