Fan noise much too loud
Discussion in 'Prime Main Forum (2017-2022)' started by Dhuntj, Feb 5, 2017.
  1. Dhuntj
    Dhuntj New Member
    washington
    Is anyone else experiencing loud fan noise? I've had my premium for a month and noticed fan noise from the first drive. I justified it based on the fact that in full electric mode things are so quiet any noise seems more pronounced. Well, the fan noise has gotten worse and become a lot more noticeable in the past week and I think it may have been louder than it should have from the beginning. It typically runs in EV mode but not all the time.
    I hate the thought of having to go to the dealer but that's probably my only option at this point. Thoughts?
  2. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    Sorry to hear that...
    What sorts of unexpected noise are you hearing? Air blowing sounds? Motor-grinding? Rattling?
  3. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Only once, temporarily. I had accidentally obstructed the charger ventilation port located below the rear console near the floor.
    I r
    Where is the noise coming from ?
    52,348
    doesn't sound right to me. i hate to say it, because i hate going to the dealer as well. especially for a noise they'll probably tell you is normal.
    on our test drive, i never heard the fan, but we didn't get as much ev as i would have liked, and it was about 40 degrees out.
    for what it's worth, i've never heard the fan in any pri, but i'm half deaf.
  5. vegan
    vegan Junior Member
    25
    Knoxville TN
    2015 Prius v wagon
    I had loud fan noise, too.
    When I went to the dealer they discovered a mouse had taken leaves into the fan area.
    Cleaned it out, and the noise is gone.
    Under $100 repair.
  6. VTBIGDOG
    VTBIGDOG Active Member
    211
    146
    Are you talking about the Heating/Cooling fan for the cabin? If so, is it set in RECIRC Mode as opposed to receiving outside air. or do you by chance have a vent or 2 that are closed?
    Also it might be you have a ventilation door that is out of alignment, which means a trip to the dealer anyway.
  7. bisco
    52,348
    i was assuming battery cooling due to mention of ev mode. my bad.:oops:
  8. VTBIGDOG
    211
    146
    You may also want to see if the S-FLOW mode is set, which redirects most of the air to the drivers area
  9. Mendel Leisk
    41,858
    Yeah maybe clarify: which fan? At least, where does the sound seem to be coming from? Dash? Engine bay? Rear of car?
  10. huskers
    huskers Senior Member
    2,546
    2,487
    Nebraska
    That is kind of gross. I am not a FAN of mice.
    Insirt likes this.
  11. mr88cet
    2,313
    1,335
    Austin, TX
    Just checking: You're referring to the battery cooling fan, or the cabin ventilation fan?
  12. Mendel Leisk
    41,858
  13. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    Did you hear the noise from inside the cabin with windows up or outside the car?
  14. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    what is your other half?:p
  15. bisco
    52,348
  16. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    It is a brand new car.
    That is what your warranty IS FOR.
    The dealer is also responsible for explaining things like this that might turn out to be "normal" for that model but unusual in general.
    TAKE IT IN.....SOON.....just incase there is something wrong that will get worse.
  17. huskers
    2,546
    2,487
    Nebraska
    And report back to us.
  18. bisco
    52,348
    fan noise? are you talking about the Super Bowl?
    bowang likes this.
  19. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Is that today?
    EDIT: Oh yeah, I guess it is.
    bowang and bisco like this.
  20. bisco
    52,348
    i wish it wasn't.
