Fan only uses front vents
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Trontite, Jul 24, 2017.
  1. Trontite
    Trontite New Member
    vancouver, BC
    I bought a 2012 c4 two years ago and I love it.
    Suddenly I am unable to switch the air flow to feet or windshield. The windshield button makes it blow out the front vents.
    Is there an actuator i can check for blockage? fuse(s) could i check to rule out? Could something have been unplugged?
    52,408
    it's usually a stuck damper, but they are way inside the dash and a nightmare to get to.
    when you press the button, with the engine off, can you hear any sounds of movement?
  3. Trontite
    Trontite New Member
    vancouver, BC
    With the engine off, I don't hear any movement. Approximately where is the possible culprit damper?
    52,408
    buried near the beginning of the vent system. you can find it in an online parts breakdown, and repair procedure at toyota tech info.
    but if you're not hearing anything at all, it's possible you have a bad switch, wiring or fuse.
    any of the hvac buttons stuck down?
  5. Trontite
    Trontite New Member
    vancouver, BC
    After some time, I did notice a weird noise coming from the passenger side. I removed the glove box and saw a little white plastic arm piece popped out of it's housing. I reseated the piece, and everything works again. Thanks for your help!
  6. bisco
    52,408
    congrats! all the best.(y)
  7. insaner
    insaner Junior Member
    96
    Atlanta, GA and Huntsville, AL
    Care to elaborate? I’m having the same problems! Thanks.
  8. Trontite
    Trontite New Member
    vancouver, BC
    1) remove glove box
    2) locate the actuator that switches the vents between the different pathways.
    If you are having the same problem that I was, there should be a little white elbow that's clearly popped out of it's housing. Snap in back in and you should be good to go.
  9. insaner
    96
    I saw that thread and hoped that was the problem and just went out and removed glove box but couldn’t find the actuator. Do you have a picture?
  10. insaner
    96
    Oops I see I’m in this thread lol
  11. insaner
    96
    I see this is in the C forum. Mine is a generation two touring. Maybe it’s in a different place.
  12. Trontite
    Trontite New Member
    vancouver, BC
    I only know about the Prius C, but it wouldn't surprise me if it was similar. Can you hear weird noises when you change which vent it's supposed to use? The weird noise is coming from the actuator which you should be able to see/ hear more clearly now that the glove box is removed. Use a flashlight to look under there while you change vent from one area to another.
  13. insaner
    96
    Yes I hear noises and looked extensively but couldn’t see anything. I also can’t seem to find its location by searching the internet. Not my day, apparently.
  14. insaner
    96
    could you tell me which direction to look? If it’s the actuator that handles the one inside of the blower motor it seems to be functioning properly.
