Fast triple beep while driving?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Joel Pointon, Jan 25, 2019.
  1. Joel Pointon
    Joel Pointon New Member
    San Diego
    Recently while driving...I get sporadic triple beeps with no visual indicator on screen or dashboard. Happens at random times...sometimes fairly close together (5 - 10 seconds between the series of 3 rapid beeps) to longer (minutes). I am totally baffled by it...not the seat beat indicator....or any other normal audio signal. Anyone else ever experience this?
    52,349
    welcome!
    check the oil level and fob battery? just a wag
    audiodave likes this.
  3. Joel Pointon
    San Diego
    Thanks...aux battery checked...new fob battery. I will check oil.
    Thanks
  4. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    What are the voltages of each battery?
    Just because they are new doesn’t always mean they are good (some of the fob batteries that are not name brand can be below 3.0 volts and are already mostly discharged out of the package).
    Is there anything in the passenger seat during these events?
    Good luck and keep us posted (y).
  5. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    Just a wild shot in the dark but could there be something else in the car you're not aware of? A kids toy, maybe? My wife once left one of her electronic gadgets in the car and it started beeping every so often as a warning the rechargeable battery was running low. It sounded like it was coming from the dash. I thought it was the car and it drove me nuts until I finally found it inside one of the glove compartments.
    egg_salad likes this.
  6. Joel Pointon
    San Diego
  7. Joel Pointon
    San Diego
    Definitely coming from the dashboard. No kids...no toys. Thanks.
  8. Joel Pointon
    San Diego
  9. Joel Pointon
    San Diego
    Battery purchased at the dealership and inserted by the service department. 12V battery just checked and it A-OK
    Nothing on the seat. Thanks.
  10. Joel Pointon
    San Diego
    By the way...happens if the smart key fob is in the dashboard slot or in my pocket.
  11. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    So the actual voltage readings on the fob batteries are?
  12. bisco
    52,349
    anything in the o/m about a 3 beep warning?
  13. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    I looked yeasterday. There were a couple, but they were outside beeps. I don't recall seeing any inside 3-beep warnings.
  14. bisco
    52,349
    where is the outside beeper, under the hood?
  15. ericbecky
    ericbecky Hybrid Battery Hero
    4,443
    3,351
    Madison, Wisconsin
    Any chance your car has an EV button installed?
  16. dolj
    dolj Senior Member
    8,549
    4,341
    Wellington, New Zealand
    Nope, it is in the front of the RF guard.
  17. philipc
    philipc Junior Member
    38
    toronto
    Any chance that the back end of the car slid a little when you heard the beeps? I know in mine if i go around a corner in snow a little too quick and the back slides it will do 3 quick beeps. You're in San Diego so doubt that snow and sliding is your issue but just a thought.
  18. bisco
    52,349
    still could be a vsc issue though, but usually you get lights
    philipc likes this.
  19. philipc
    38
    toronto
    I agree could still be a VSC. From my experience no VSC light (or any lights) come on when it does the beep so if its miss reading a skid its possible there will be no light.
