Faster Discharge?
Discussion in 'Gen 2 Prius Technical Discussion' started by KhaPhoRa, Apr 5, 2014.
  1. KhaPhoRa
    KhaPhoRa Member
    168
    37
    Is it possible to make a simple apparatus to discharge a module at a faster rate? I understand why the small hobby chargers can only discharge at 5w or so but what challenges would one face if they were to simply use a 20watt light bulb (just as an example). Obviously monitor voltage and stop at 6v (or 6v-Vdrop?). Would you average the current using starting v and final v / watts to figure out mah discharged? I suppose on the third discharge you could use the hobby charger to get a more precise capacity. It just seems like a massive waste of time being limited to 5w discharge on 84 total module discharge cycles when even a 50w discharge should be plenty safe and sufficient for at least the first two cycles of an individual module.
    I apologize if this has been discussed before or if my understanding of the topic is way off, just brainstorming here in the event I need to rehab my hv battery someday (I love learning and researching ahead of time).
    iPhone ?
    Anthony Williams likes this.
  2. Britprius
    Britprius Senior Member
    5,194
    1,914
    Herefordshire England
    There is no problem with discharging at a higher rate. The problem is making this happen automatically.
    If the charger switching device to load the module to discharge is a relay external resistors could be fitted to give a higher discharge rate. I believe on some chargers this is possible.
    The most likely method used is some form of transistor switching, and then the problem is the current that this device can carry.
    Not having dismantled one of the chargers I do not know how the discharge switching is achieved, but it should with thought be possible to arrange extra load. This extra load may or may not be seen by the charger, but it could be calculated into the figures. The figures given out by the charger would still show any gains, but would not show real capacities.
    John (Britprius)
  3. KhaPhoRa
    KhaPhoRa Member
    168
    37
    Thank you. My thinking was to make the discharge cycle manual - as in I sit down in front of the pack, hook up some light bulbs to a few modules and carefully watch voltage, disconnect each when they get to 6v or slightly below to account for voltage drop. Then use the charger for the charge phase only. It seems too simple to work (other than having to sit and watch). But say I only do it for two cycles and let the charger do it at the slow rate on the third for the sake of precision. That could save 6 hours per module per cycle.. (300 hours if using one charger?! 75 if using four?)
    I guess my mission is to buy a module on ebay and test it out.. I agree that a method to boost the discharge rate of the charger would be awesome and optimal but I wasn't even considering anything that ambitious :)
    iPhone ?
  4. Britprius
    5,194
    1,914
    The problem with using light bulbs is that there resistance (the amount of load they apply) varies dramatically with the voltage of the battery.
    As the battery voltage falls the lamp gets dimmer "the filament is colder" and it's resistance goes down increasing the load.
    It would be better to use high wattage resistors to reduce this effect.
    Even at a 50 watt "about 6.5 amps" discharge rate at full capacity it will take around 1 hr to discharge a module.
    John (Britprius)
  5. KhaPhoRa
    KhaPhoRa Member
    168
    37
    Good info, thank you. One hour vs almost ten using a charger that maxes out at 5w for the discharge sounds like a good trade off to build a little rig.
    iPhone ?
  6. uart
    uart Senior Member
    4,215
    1,200
    Australia
    The problem with discharging at very high rates is that it's a module, not a cell, and you can't monitor the individual cell voltages.
    Remember that you're trying to balance the internal cells, but you don't know how well they are initially balanced. If one cells is hold less capacity than the other five, then at 6.0 volts you could have 5 cells at 1.2 volts and one at zero. This is where you start reverse biasing one cell and damaging it further. The basic idea is that if this undesirable situation happens, at least it wont do any damage if the discharge current is low enough (eg C/10 for example).
  7. KhaPhoRa
    KhaPhoRa Member
    168
    37
    If I'm discharging a module to 6v and one cell drops to zero then that module would be bad anyway, right? What is the discharge rate of any one module under heavy driving conditions? It's got to be at least 5c or so, probably higher? if it can survive that during the (admittedly narrow) charge cycle in the car then it should be ok at 1c on the bench?
    I promise I'm not trying to be difficult, this is just how I try to work through things. I was raised to immediately doubt any shortcuts (my father built homes from the foundation up and shortcuts meant quality cuts) so I'm skeptical myself, but I see this as a limit of the hardware - hobby chargers not built to dissipate heat quickly..
    Edit: I think my in-my-head math is off on the max discharge rate.
  8. uart
    uart Senior Member
    4,215
    1,200
    Australia
    No. One cell only has to have 0.1 A-hr less charge than the others to discharge to zero and reverse bias while the others are still discharging. This sort of thing could easily happen.
  9. KhaPhoRa
    KhaPhoRa Member
    168
    37
    Does anyone here have a module they would be willing to loan or sell so I can test things out? I want to build a simple affordable rig that anyone here could duplicate. I want to test it using my thunder ac6 charger to accurately measure capacity then compare that to the rig to come up with a simple time/mah graph (this should be linear right?) so capacity can be estimated.
    Hopefully I'll never need to rebuild one but others will and anything that could safely help people get back on the road sooner is good. Maybe figure out a way to add in a 6v auto-off so it wouldn't have to be watched constantly...
    I just tested my traction battery and my delta V never went over 0.14v through a full stress test (and the low bank kept changing through that test). I hope that's a good sign, it's a 2006 with 148k so I'm in the "start thinking about options phase".
    iPhone ?
  10. Britprius
    5,194
    1,914
    Uart does bring up a valid point that could be somewhat alleviated by doing a charge cycle first. This would help with an initial balancing effect, but would mean another charge only cycle at the end.
    John (Britprius)
  11. KhaPhoRa
    KhaPhoRa Member
    168
    37
    You'd still be way way ahead time wise. Especially considering the module will be at least 40% charged to begin with.
    iPhone ?
  12. Jason in OZ
    Jason in OZ Active Member
    271
    112
    Sydney, Australia
    have you considered a better charger / discharger ?
    like this one ?
    Revolectrix
    i have 2 of them for my RC cars and planes and boats etc.
    this one can charge at insanely high rates (1344w) and discharge at healthy levels too (100w)
    or 1344w regen discharge, where the discharged power is put back into the source battery (if the charger is powered by a battery)
    the downside is that these need higher than 24V (or more) psu in order to get the max charge rates.
    i have a 24V 41A supply that i use at home with it.
    Jason.
  13. KhaPhoRa
    KhaPhoRa Member
    168
    37
    That's a nice unit, I love the idea of the regen discharge, but $250 for the unit and another $150 or so for the power supply isn't practical. And is that just to do one module at a time? If so that's $1600 to do four modules at a time. At that price it wouldn't make sense for an individual who isn't planning on rehabbing batteries for a living. If I'm wrong and it'll do four modules at once then it's not bad.
    I found a schematic of an auto-shutoff circuit with a variable cut off voltage, cost of parts is $5, add another $5 for a resistor to handle the high current discharge. Two of those and a four port hitec charger with power supply built in for around $250 total or $150 if you already have a power supply.
    iPhone ?
  14. Jason in OZ
    271
    112
    Sydney, Australia
    yeah, they are kinda pricey...
    i believe they will do up to 20 NIMH cells in series.
    so you could do multiple modules at once if you wanted to.
    the ones i have were the re branded turnigy chargers. still built by the same factory,
    under license and being the re branded ones, i got them for lots less than the revolectrix ones.
    Jason
  15. KhaPhoRa
    KhaPhoRa Member
    168
    37
    That's an awesome charger, I want! :) if it does 20 cells then we could do three modules at once helping out the cost factor. I'm envisioning a setup where someone can recondition an entire hv pack in a day.. Hmmmm....
    iPhone ?
  16. KhaPhoRa
    KhaPhoRa Member
    168
    37
    Regarding my post about the $10 discharger, if I were to build that discharger I'd target the discharge at 0.66C and then charge at 0.33C using the hobby charger (I'm using those numbers assuming I would build two dischargers and use a four port hobby charger). Assuming 0.1C discharge from a hobby charger this would cut the theoretical time to balance one module from 39hours to 16.5hours. 28 modules later you've cut 630(!!!) hours from the project (obviously divide that by the number of chargers if using more than one). And that time difference includes the extra initial charge mentioned previously on the faster method. I still honestly believe there is no harm in bumping those rates up even higher for three cycles.
    Now here is where I start thinking again... Dangerous territory according to my wife..
    First: I no longer see a need to do a slower 0.1C discharge so the hobby charger can tell me capacity. As long as I use the same method for all modules and the same calculations time will be the important measure. On the final cycle starting V and ending V(minus v drop if significant) can be the same, the load is obviously the same so the average watts should be the same meaning time to discharge is all that matters. Higher discharge rates will reduce a measured mah rating somewhat (very little at only 1C), but that's just a measurement at a given discharge rate. We could change the measured capacity several ways depending on the method on the same module, but it doesn't change the condition of the module. We should be less interested in a theoretical maximum capacity as we are in a balanced and matched set of modules. Keep the method the same.
    Second: I still say discharge first. If three discharges to 1v per cell at 1C were dangerous there wouldn't be a hobby nimh pack left after a week of use (they have discharge rates much much higher than 1C). Then trickle charge at 0.05C give or take (perhaps a two stage charge to save time if you have the capability). Without some way of individually controlling the discharge of individual cells they won't balance from a discharge anyway. The balancing comes from a trickle charge at the end of the charge cycle. I think we would see a higher and more consistent benefit of balancing using that method. Fill up those lagging cells with no threat of heat build up in the higher charged ones. We wouldn't have to worry about any mah safety cutoff or guessing what that number should be; these aren't lipos. Boosting the discharge would buy us more than enough time to make up for a good trickle charge at the end of a fast charge cycle. 0.1C discharge is just not logical, it's just the limit of the hobby charger to keep it cheaper. Standard practice for conditioning nickel based packs is to trickle charge unless you have means to manage each cell individually (with a tray charger for instance). We can't do that.
    Third, an unbalanced cell is like a runaway train. It will charge to higher voltage degrading it's capacity even more resulting in higher charge voltage next charge degrading it even more.. On and on and on. The narrow charge cycle of the traction battery is brilliant in slowing that process but it will still happen.. Best thing would be a way to trickle charge that whole darn pack to balance it all once in a while. Why wait for one or two modules to get so far out of balance that we have a failure?
    iPhone ?
  17. SuperDave
    SuperDave Member
    104
    22
    Anderson, In.
    Kha Your question is a very good one. I have a long and extensive background working with RC car batteries (NiCad-Nickel metal and Lipos), and have been wondering the exact same thing.
    Over the years in the competitive RC car field, the discharge rates have climbed. We started out at 10 amp and now many cycle at 50 amp. Now I fully understand that it is not needed to discharge a Prius battery that hard, but somewhere in between would be more useful and time saving.
    The idea of the always higher discharge rates in RC racing is to simulate on track amp draw, which has increased as battery capacity has raised and motors used more. Also many believe that a higher discharge rate will help "weed out" any weak or bad cells before they are put into use. Now with the Prius module and with the very low discharge rates that many are using, I could see a module checking ok and then failing when in actual use.
    I just bought 3 Hitec X4 eighty's, and now I am having second thoughts (I kind of did when I ordered them). There are a number of good used RC charger/dischargers/cyclers that could be picked up at a good price now that many in RC have moved on the Lipo batteries.
  18. SuperDave
    SuperDave Member
    104
    22
    Anderson, In.
    Kha To address one of your original questions. Could a simple string a light bulbs be used to discharge a module? Yes it sure could. We used to use them all the time before the electronics advanced. All that would be required are a voltmeter , stopwatch (timer) and a string of light bulbs. We used to use 1157 tail/brake light bulbs, if I remember correctly each one would pull about 1.5 amps on a 7.2 volt pack. Some may suggest that with heat the load may change, and it does slightly but it will be the same change every time. The way I see it a slightly less amp draw toward the end of the cycle when the battery is lower is not totally a bad thing.
  19. KhaPhoRa
    KhaPhoRa Member
    168
    37
    For a second I read that as "we used over 1100 light bulbs" and I imagined a glorious set up :) I agree, keep the method the same and the variables (other than time) will even out for finding modules that are shot.
    What is your opinion on a trickle charge at the end of a rapid charge? If you do three cycles would you trickle on all three? Only the first? Last? Is three cycles still the norm for reconditioning?
    These nimh cells in the prius are going to be fine with rapid charging and discharging. Be gentle with the balance portion for obvious reasons and I can see a four charger setup doing a whole pack on a weekend easily, assuming a two stage charge.
    iPhone ?
  20. KhaPhoRa
    KhaPhoRa Member
    168
    37
    Okay next question.. What would be necessary to trickle charge this pack as one unit while still in the car? I havent looked around here enough but I bet someone here (lots of great minds) has already done it. I'm almost certain a once or twice a year balance would help everyone get the most out of these packs. Yes any rechargeable will eventually degrade, but these failures all seem to be caused by one or two severely unbalanced cells that went into a death spiral and could have been avoided.
    iPhone ?
