faster voice command
Discussion in 'Gen 3 Prius Main Forum' started by chip_designer, Jun 8, 2010.
  1. chip_designer
    chip_designer New Member
    50
    silicon valley
    Hello,
    I did not bother to look at the navigation manual yet, but when I use the voice command, the prompter women voice repeat too much before we can answer. such as:
    "2451 , is it correct
    if not, is it one of the numbers below? if not
    say go back"
    the voice command does not recognize my numbers;
    when I say 24, it understood "04"
    when I say 2451, it understood "04451"
    so I went back and forth 5 times, I already arrived at my destination.
    my questions is there any voice recognition calibration ? so it will
    recognize my voice better
    and are there any way to speed up the voice prompter, instead of waiting for her to repeat the options and wait for the beep before answering.
  2. davidtx
    davidtx New Member
    Dripping Springs, TX
    You can push the voice command button while she is enumerating commands and it will immediately switch to listening mode.
    cool - I've had my Prius for 3 hours now and already answered a tech question.
  3. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Comments in bold below
  4. silentak1
    silentak1 Since 2005
    893
    28
    LA
    1. Click on SETUP
    2. Then VOICE
    3. "Voice Recognition Guidance: OFF"
    That speeds things up, also what the people mentioned above...you can cut off the waiting part by just hitting the voice button again. ;)
  5. chip_designer
    50
    silicon valley
    THANks a lot! I will read it too now..
    But i guess my accent is too much, even i speak individual digits,
    it does not get it right.
