Fastners Under Rear Seat
Discussion in 'Prius c Main Forum' started by WD0AFQ, Aug 10, 2012.
  1. WD0AFQ
    WD0AFQ Active Member
    619
    152
    Dexter, Mo.
    I can not figure out how to get those little fastners out. I want to put a cigarette light under there to run some of my electronics. How do those things come loose so I can get to the battery?
    Thanks,
    Dan
  2. JLee81
    JLee81 Junior Member
    56
    Maryland
    If you're talking about the plastic cover around the bottom of the seat you just need to take something that won't scratch the plastic (like a small philips screwdriver with a little tape over the end) and push in the center of each fastener. It will push in and allow you to pull the fastener out.
    WD0AFQ likes this.
  3. WD0AFQ
    619
    152
    Dexter, Mo.
    Thank you very much. I just could not figure out how to get them out.
    Dan
  4. JLee81
    56
    Maryland
    One of mine broke when I tried to get it out. I think it may have been messed up when it was originally installed. All the others were easy to get out. Good luck with your mod. Please post some pics when it's done.
    SGH-T989 ? 2
  5. WD0AFQ
    619
    152
    Dexter, Mo.
    Ok, I will try to be very careful. Want to drill a hole and mount the recepticle.
    Dan
