Fault code B0000
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by morm3993, Oct 7, 2017.
  1. morm3993
    morm3993 Junior Member
    25
    US
    I suspect my hybrid battery is on the fritz. I can't find anything on fault code B0000.
    Any help?
    49,380
    what are you reading the code with?
  3. morm3993
    25
    US
    Some cheap code reader I got off ebay and the torque light app.
    49,380
    you'll probably need mini vci and tech stream. what behavior and lights are exhibiting?
  5. morm3993
    25
    US
    Last week the ABS and VCS and the (!) Lights came on.
    The red triangle of death did NOT come on.
    The lights turned off on restart. The wisdom of prius chat was that the DC converter may be the issue.
    The dishonest morons at the toyota dealership I took it to refused/failed to look at or test the DC converter and said they couldn't get the codes back on.
    I drove it a nike and all the lights popped back on and this time the red triangle did turn on. Dealership suggested the hybrid battery needs to be replaced. Drove the car over 200 miles before the codes came back on. But this time different codes came on.
  6. bisco
    49,380
    you're showing a 2012 in the gen 2 forums. what are you driving and how many miles?
  7. morm3993
    25
    US
    I reset the codes and drove around and they didn't cone back on. I'm looking into a refurbished battery to keep the car going.
  8. morm3993
    25
    US
    I have a 12 and a 2005. The 2005 has 298k. This is the 05.
  9. bisco
    49,380
    how is the 12v health?
  10. morm3993
    25
    US
    It passed the dealership testing they did for the oil change the other day.
  11. bisco
    49,380
    not sure i would trust dishonest morons on that.
  12. morm3993
    25
    US
    I know. They are the closest dealership around. And other than an oil change and a detail, I have never been real happy with them.
    The place where I can get a refurbished battery and, if necessary, a new DC converter are even further away.
  13. bisco
    49,380
    refurbished batteries can be a scam, have you read up on them here?
  14. morm3993
    25
    US
  15. bisco
    49,380
    there's no such thing as a reliable refurbished battery. so it is only as good as the warranty, and the company standing behind it. there are a lot of rip off artists in the business, taking advantage of naive prius owners, then either not honoring the warranty, or unable to get hold of.
    Raytheeagle likes this.
  16. TMR-JWAP
    TMR-JWAP Senior Member
    6,193
    5,891
    Columbia, SC
    morm,
    other than "US" where are you?
    Sometimes you get lucky. You may be next door to a member with test equipment and not know it.
  17. morm3993
    25
    US
  18. TMR-JWAP
    6,193
    5,891
    Columbia, SC
    Unfortunately, that's a long ride from South Carolina........
  19. bisco
    49,380
    or anywhere...
  20. morm3993
    25
    US
