Fault code p0171
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by moha777, Jun 5, 2020.
  1. moha777
    moha777 Junior Member
    GB
    Hi
    As I have replaced both 02 sensors in my 2008 Prius with 189k miles its throwing another code with engine power loose.with red triangles lights on once fault code resetted I am getting engine management light in few miles drive.i have attached the fault code anyone experienced the same please advise. 20200605_121720.jpeg
  2. JC91006
    16,482
    8,399
    Did you use Denso parts? Many aftermarket o2 sensors don't work well with the car.
    SFO likes this.
  3. ChapmanF
    15,581
    So the sensors are saying the mixture is lean.
    That doesn't always mean the sensors are bad. Sometimes the mixture is lean. It's their job to sense that.
    Can that reader show the bank 1 long term fuel trim?
    Have you checked for intake leaks, low fuel pump pressure, injector issues?
    moha777 and SFO like this.
  4. moha777
    GB
    But my auto electrician told me that's the fault.but I need to get fuel pressure and injectors checked
  5. dolj
    dolj Senior Member
    7,651
    3,860
    Wellington, New Zealand
    What exactly did the auto electrician say?
    P0171 doesn't necessarily mean the O sensor is broken.
    DTC P0171 System Too Lean (Fuel Trim)
    Trouble Areas:
    • Air induction system
    • Injector has blockage
    • Mass Airflow meter
    • Engine coolant temperature sensor
    • Fuel pressure
    • Gas leakage in the exhaust system
    • Open or short in A/F sensor (bank 1 sensor 1) circuit
    • A/F sensor (bank 1 sensor 1)
    • A/F sensor heater (bank 1 sensor 1)
    • EFI M relay (integration relay)
    • PCV valve and hose - PCV hose connection
    • ECM
    #5 dolj, Jun 8, 2020
