Faults PO420 (catalyst system efficiency below threshold) .
Discussion in 'Gen 3 Prius Main Forum' started by dgm1214, Sep 15, 2024 at 6:34 PM.
  1. dgm1214
    dgm1214 Junior Member
    Wellman, iowa
    This popped up after replacing both oxygen sensors, on a 2013 with 177k miles. Prior error was related to faulty downstream oxygen sensor, and found wires from connector damaged. Did this work myself with sensors off Amazon, about $40 each.
    Wondering if I did something wrong ?
    Thanks !
  2. dgm1214
    Wellman, iowa
    Update, reset codes again, and after 50 miles NO codes popped up. Will test drive tomorrow too.
    49,787
  4. dgm1214
    Wellman, iowa
    Update2. Drove only about 5 miles today before engine light appeared. Same 2 codes as before
    1) P0420 catalyst system efficiency below threshold Bank 1
    2) vehicle has no faults
    wondering why it says ‘no faults’ when it reported a P0420.
    Not sure if I should drive it on a trip, 700 miles one way into Canada, or not.
    Thanks for suggestions.
    #4 dgm1214, Sep 16, 2024 at 3:16 PM
  5. bisco
    49,787
    were the new sensors oem?
