faulty fuel gauge?
Discussion in 'Gen 2 Prius Fuel Economy' started by inkybrown, Feb 15, 2009.
  1. inkybrown
    inkybrown Junior Member
    16
    Fort Worth, TX
    Last week I was really disturbed by something that happened with my fuel gauge. The gauge started flashing because I was low on gas. So I pulled over to the first gas station to get some gas. The gas was really expensive so I only put in about 3 gallons. When I started driving again, the gas gauge was still flashing that it was almost empty. I drove for about 5 miles, and the gas I had just purchased never registered to my car's gauge. I started thinking the gas station had ripped me off or something, but I didn't have time to go back so I pulled over to the next gas station I found and filled up the rest of the way. It only took about 6 gallons, so I know that the first fill-up I did must have put something in there. Finally, this time the gas gauge registered that I had gas and stopped flashing.
    Does anyone have any idea why the gauge did not register that I put the gas in the first time? Has anyone had this problem? It really freaked me out!
    Thanks.
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    If you only put just a few gallons (I thought 1-2 but 3 I guess as well) it doesn't register... Nothing to worry about.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    The answer to your question is covered in the owner's manual. You need to add more than three gallons before the addition will register.
    Tom
  4. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    It's a pretty dumb gauge, as gauges go.
  5. qbee42
    18,058
    3,074
    Northern Michigan
    Exceeded, perhaps, only by the dumbness of the typical driver.
    Tom
  6. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Lol, true but I still like the digital gauge over an analog so I'll accept having to put in more than 3 gallons and have it register.
  7. patsparks
    10,664
    567
    Adelaide South Australia
    I would rather just look for fuel when I have 2 bars on the gauge then I can keep going until I find a cheaper price station within 50km of my travels without the fear of running out.
  8. Celtic Blue
    2,224
    139
    Midwest
    Doesn't really matter to me whether the gauge is digital or analog as long as it can actually show the fuel level. A gauge that can't tell/display the difference between adding 25% of the total tank capacity is close to worthless. When did partial fills become a crime?
    I mean, what numbskull said, "Hey, I've got an idea! Let's not show a level if the user only adds 3 gallons on a fill!" Hint to Toyota: send this person to the front of the unemployment line...and right behind him/her should be those who approved it.
    A good gauge will display what it can detect. It won't lie to you about the level. I don't care whether it uses a "Hello Kitty" pointer as that is aesthetics, but I do expect it to show me the level. :D
    Toyota so missed the boat on the North American fuel system.
  9. Celtic Blue
    2,224
    139
    Midwest
    I guess you are speaking for yourself. Most people I know can actually read a gauge. They also frown on gauges that intentionally lie to them and consider them defective. However, you seem to be the chief defender of the screwed up fueling system in this car.
  10. patsparks
    10,664
    567
    Fuel system seems fine to me, it feeds just the right amount of fuel to the engine.
  11. qbee42
    18,058
    3,074
    Northern Michigan
    That was a generic comment. I find most drivers pretty stupid, and not just related to reading fuel gauges.
    I do tend to defend the fuel system, but mostly because it's not as bad as some make out. You seem to be the chief critic, to the point of being almost obsessed. It has its problems and shortcomings, but at the end of the day it does its job. I have owned cars with faulty fuel gauges, and my Prius isn't one of them. I always know when to refuel.
    One of the problems with digital gauges is that they tend to be more precise, but not necessarily more accurate. If you give someone an analog gauge with vague markings, they will happily tell you that they have a half tank, or three-quarters of a tank. If you give them 10 little pips they expect each pip to accurately represent 10% of the tank volume, even if you are supplying the information from the same inaccurate float. Give them 100 pips and they expect 1% accuracy. It's like measuring with a micrometer and cutting with an ax.
    This isn't just a problem with cars. Most airplanes that I have flown have fairly primitive fuel gauges. To get a good idea of remaining fuel you have to measure what was put into the tanks and calculate from the burn rate. Boats are even worse. Many of those require the use of a dip stick to measure fuel levels, which is hard to do under way.
    Now before you go and post another nasty reply, let me repeat something I have said many times on previous posts: I freely acknowledge that the refueling system and fuel gauge on the current Prius is sub-optimal. It is overly complex, fussy, and lacks repeatability. On the other hand, it generally works. Only a very small minority of Prius owners report problems with refueling, and the gas gauge works just fine for the primary task of telling you when to refill. Could it be better? Yes. Is it an unmitigated disaster? No. Given that the 2010 has moved past this design, it's probably time to let this go.
    Tom
  12. patsparks
    10,664
    567
    What he said, I couldn't have said it better without swearing.
  13. Celtic Blue
    2,224
    139
    Midwest
    Obsessed? That's what I think of your defense of an obviously fatally flawed system. No, I'm not obsessed, but I will rebut BS. I remain puzzled as to why you immediately jump to the defense of a system you occasionally acknowledge is flawed and instead seek to blame the user.
    Why would anyone consider a digital gauge with 10 pips more precise? It is less precise because it only shows ten steps. An analog gauge can show a full range with few if any steps (typically only on the very ends...off scale.) And with a normal gauge the user soon learns to read the hysteresis of the gauge in various situtations. This gauge is so heavily "filtered" that it fails in its primary role of providing information to the driver. (If it instead provided a percent reading that was easy to discern in 1% or 2%, etc. increments then I would tend to agree with your precision claim.)
