Favorite front brake pads? Or go OEM?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mcmars, Sep 26, 2021.
  1. mcmars
    mcmars Member
    61
    30
    4 corners/SW US
    I am looking to see if people here have found a good aftermarket set of front brake brake pads for a 2008 2nd gen prius? No issues at 165K miles, but they are looking very thin now.
    I normally spring for OEM pads, but they are over $80 on amazon now. Other choices that looked like possibilities are the Wagner ZD990 ($28.47) or Wagner qc 990 ($33.10). The bosch were the cheapest and most popular, but many reviews are claiming problems or scams with them. I am leaning towards the OEM toyota pads as I will keep this car for a while, but thought I would see if some of the folks here know a good alternative? Thanks so much everyone!
    52,396
    oem, long term safety investment. not sure about amazon, watch out for counterfeits
    Pulse07, Kasra and Mendel Leisk like this.
  3. ChapmanF
    18,560
    Second that. I'm seeing $76.20 at some Toyota dealers, you know what you're getting.
    Reports about counterfeit pads have been kind of hair-raising ... some using materials that aren't even flameproof.
    With Amazon, it doesn't seem to be necessarily useful even to go by seller reviews and pick a specific seller ... because if they have seller A and seller B who list the "same" item, and you order it "from" seller A, and Amazon sees that they have seller B's stock in a nearer warehouse, it's possible they might just send you that.
    The Automotive Anti-Counterfeiting Council whitepaper linked above kind of tiptoed around the actual name(s) of the "at least one" online marketplace that does that, but I'm pretty sure I've had it happen to me, when I ordered on you-know-where.
  4. Mendel Leisk
    41,921
    Yeah something you’re doing so infrequently, and a lot riding on it.
  5. mcmars
    mcmars Member
    61
    30
    4 corners/SW US
    Thanks everyone! I will go with OEM. The nearest toyota dealer is 2 hours away, but I have a doc appointment tomorrow and will try and stop by and get them from dealer. I had no idea the counterfeit thing was happening with brake pads, that might explain some of the reviews I read. Loving my prius, 3 years and 20K later and all good. I installed a toyota OEM new high volt battery when I got it, so not planning to let it go anytime soon, the OEM brakes it will be.
  6. Mendel Leisk
    41,921
    You're doing all four, front and rear?
  7. bisco
    52,396
    first post only mentions front
  8. Mendel Leisk
    41,921
  9. bisco
    52,396
    if you don't make it, lots of dealers sell online
  10. Kasra
    Kasra Member
    48
    27
    Irvine, CA
    Akebono is a great brand for replacement but the ones sold by Amazon itself were counterfeits...OEM is worth the hassle!
  11. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
  12. nancytheprius
    nancytheprius Active Member
    365
    156
    iowa
    i got pads from amazon for 20 dollars and ended up needing to replace them a month later, because they started clunking! learn from my mistake and avoid the hassle
