favorite gasoline brands?
Discussion in 'Gen 3 Prius Fuel Economy' started by barbaram, Aug 18, 2009.
  1. barbaram
    barbaram Active Member
    911
    70
    Trenton, NJ
    I'm asking the perpetual question... which gasoline brand do you use and any comments.
    I've been using exxon for a while. thinking of trying shell again- i had some bad mileage last year with the '06 but they have changed the formula?
  2. jay_man2
    jay_man2 jay_man_also
    1,246
    143
    Manassas, VA
    Toyota and some other manufacturers have banded together to recommend "Top Tier" gas for their vehicles. I don't know if I buy into it, but I get a 5% rebate with my Shell Visa, so I use Shell; if there's a big difference in price between Shell and Costco, I'll sometimes use Costco.
    Top Tier Gasoline
  3. lefat1
    lefat1 Fat Member
    1,476
    47
    Sunny S. Florida
    I've been using gas that is supposedly not from the middle east. These are to include: Hess, Citgo, Costco which I believe is BP and a few others.
  4. Spartane
    Spartane Member
    149
    43
    Mississauga, Canada
    1. Shell regular seems to work well.
    2. Petro-Canada regular offered about 5% poorer mileage than Shell regular (this was a bit surprising -- I expected it to be as good as or better than Shell).
    3. Running Shell Premium right now -- so far the mileage seems the same or maybe a bit better than Shell regular, but the tank is still nearly full so it's too early to tell.
  5. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    I believe there is a difference between "top tier" fuel and fuel that isn't. Level of detergent is only one, but important difference.
  6. TKY
    TKY Member
    232
    25
    Colorado
    I agree with a64pilot. My understanding is when a tanker unloads, it's just gasoline. Then refiners buy the gas and mix additives to the specs requested by the retailer. The differences is just the additives. --TK
  7. PeteJE
    PeteJE Junior Member
    87
    Sierra Madre
    I use Valero. Our 76 in town got bought by the guy who owned the Valero - now we just have two Valeros, literally one block from each other.
    Anyone know about their quality?
  8. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I generally use Chevron (one of the top tier brands), which contains techron. You can also buy bottles of techron at the auto parts store.
  9. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    My last two tanks were cut rate gas stations. Fred Meyer and another off the wall station in Longview Washington, both contained 10% ethanol.
    Mileage was over 55 MPG both times, calculated, not MFD.
    The only difference you will find is a gas station that does not use Ethanol. Than you will get more Miles Per Gallon.
    alfon
  10. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    I use BP for that reason. However, I totally avoid CITGO as well. While the gas stations may be privately owned, the oil from Venezuela, CITGO is a state owned company controlled by a man that would love nothing more than to see the US completely destroyed. I don't place Chavez any higher on my list of US friends than I do Iran.
  11. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    Some of your stations (where they sell food and groceries_won't mention names) use an off spec gasoline. Doesn't mean it's bad, just that it didn't meet the specifications of those companies that requested a certain blend with specific additives.
  12. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    99.9999% of the people here and in car magazines will tell you that you're wasting your money with Premium unless your cars engine was designed to run on premium. I'd agree with them. There are other threads for this discussion though.
  13. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    It get the cheapest. It all pretty much comes from the same tap up here.
  14. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    Does Alaska have refineries or does the oil get shipped out and then gasoline shipped back?
  15. eaglesight333
    eaglesight333 Senior Member
    6,310
    77
    Northern, IL
    I used to get the cheapest (grocery store, sams club, etc) until I realzied it was causing issues with my old car (96 chevy lumina). Switched to Shell and BP, issues went away. Will never go the cheap route again, especially with 2010 prius.
  16. MikeDS
    MikeDS Member
    298
    Los Angeles
    With a car as efficient as the Prius, there doesn't seem much point to going cheap. We're usually only talking about $1 savings every 600 miles...
  17. barbaram
    911
    70
    Trenton, NJ
    There are plenty of threads in the prior version threads about gasoline and the additives.
    I just peeked at Valero's website and it's pretty impressive- they have a big "social responsibility" report.
    CITGO is definitely banned and has been for a long time. I have mostly sunoco, shell, exxon here. BP an hess are hard to find. Plus many stations have started the BS of charging extra $.10 per gallon for credit cards. sorry i won't shop there.
  18. blippo
    blippo New Member
    255
    VA
  19. hm800x
    hm800x New Member
    Quebec Canada
    You're right about this. I've worked in a Valero (Ultramar in Canada) refinery and at the tanker truck loading ramp there was a first stop to load the gasoline and a second stop for additives for each ''branded'' gasoline. I don't remember all brands but there was Shell, Petro-Canada, Esso and evidently Ultramar.
  20. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    I've burned many brands over the hears and found that in my Honda's and Toyota's, none of them had a problem with any brand. I currently burn Speedway in both cars and have not had any problems. This is the station close to home although when traveling, I burn what is conveniently located.
