Feather eliminate oil in throttle body
Discussion in 'Gen 3 Prius Main Forum' started by Tekken, Jan 2, 2022.
  1. Tekken
    Tekken Member
    260
    77
    Los Angeles, California
    Since my commute increased due to my work relocated, 400 miles per week up hill drive, 3000+ RPM drive
    • Every week, I see 1.5-2 Tables Spoon of oil @ throttle body
    • Oil Catch cans installed with limited oil amount of catch due to oil vapor from PCV
    • Dual oil catch cans not an ideal result
    • What else can feather eliminate oil trap @ throttle body?
    Feel free to advise.
  2. ChapmanF
    18,958
  3. xliderider
    xliderider Senior Member
    8,140
    3,278
    Honolulu, HI
    I think you mean further, not feather?
    Although, I understand down feathers are excellent absorbent material for absorbing oil spills in booms.
    Check out my post, https://priuschat.com/index.php?posts/3200052
    I use fine stainless steel mesh to specifically catch oil mist in the PCV circuit to the intake manifold. It seems to be pretty effective, much more so than just using the stainless potscrubber material alone.
  4. Mendel Leisk
    42,266
    If it’s a cheap oil catch can, maybe trying another manufacturer might improve the catch? Dual cans do catch more, but in my experience, they’re mostly effective during winter, and the catch is maybe 80% water.
  5. xliderider
    8,140
    3,278
    Honolulu, HI
  6. rjparker
    rjparker Tu Humilde Sirviente
    11,004
    6,894
    Texas Hill Country
    Sintered bronze is better but are in expensive catch cans.
  7. xliderider
    8,140
    3,278
    Honolulu, HI
    They are also potentially much more restrictive. If not kept clean, it could cause high crankcase pressures and potentially damage seals.
  8. xliderider
    8,140
    3,278
    Honolulu, HI
    I believe it is more important to provide as much surface area as possible for the oil vapor/droplets to condense and consolidate on, than it is to filter through a small size filter media.
    My stainless steel fine mesh filters are made by rolling up the mesh into tubes with 3 to 4 layers of mesh in the wall, then one end is flattened and folded over to seal. Then the resulting cone is filled with stainless potscrubber to further increase the available surface area. In use, the oil mist/vapor does indeed condense and consolidate on the mesh and potscrubber material, then gravity pulls the oil down to the bottom of the mesh cone to drip into the catch can.
    In this picture, you can see the oil at the bottom of the mesh cone (outlet side).
    The sintered brass filter in those expensive oil catch cans have a sintered brass filter with the surface area about the size of the face of a quarter. 20211116_104641.jpeg
  9. Tekken
    Tekken Member
    260
    77
    Thank you for everyone input
    I have a similar setup as xliderider's posted without mesh.. but my OCC has Sintered bronze and I've added stainless steel scrubbers in. I mounted the OCC below PCV that could be decease Oil Vapor trapping.
    Back on 3 months ago, my commutes were low, average 600 miles per month and most of my drives were used EV mode
    Now, my commutes are 3 x more and used ECO mode on high way drive.
  10. Tekken
    Tekken Member
    260
    77
    Is anyone has used Provent 200 Oil Separator on Gen 3 Prius? It seems like it can separate oil vapor on
  11. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    why not just fill the catch can with a quality steel wool
  12. xliderider
    8,140
    3,278
    Honolulu, HI
    What prevents the flow from the inlet from going over the top of the quality steel wool sitting in the bottom of the catch can and out the outlet?
  13. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    Catch cans are not complicated. Decent ones use chamber size, a labyrinth/baffle path and/or media to remove oil from the vapor. My 'steel wool' is the same thing you call 'pot scrubber'.
    I'm curious about your photos in post 5. You say you reversed the manufacturers recommendation and made the larger port the outlet port. I've seen some that have a 'larger' inlet port because they had a bronze filter installed, was that the case with yours? You pulled that off and installed your mesh? You show the large screen mesh being packed with pieces of steel 'pot scrubber'. Last time I looked at one of these (and it's been a few years since my racing days) the inlet and outlet ports are completely open passages. You don't have any concerns having that material on your low pressure (suction) side of the can? Isn't that a bit like throwing loose debris on the throttle body side of your air filter? Are you going with the thought that it's relatively heavy and won't get pulled through? Am I misunderstanding your setup?
    #13 TMR-JWAP, Jan 8, 2022
  14. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    A good can with a baffle
    and
    why not just fill means more than a piece on the bottom
    But I have zero work experience with mass produced catch cans, so maybe they don't have a decent baffle/condensing/drain system
  15. Tekken
    Tekken Member
    260
    77
    Here're the image of the current my OCC setup with steel wool and Sintered bronze. Weekly commute 400 miles and 1.5 -- 2 Tsp of oil trapped @ throttle body
  16. Tekken
    Tekken Member
    260
    77
    My OCC is mishimoto. I'm putting it back as original Mishimoto OCC with Baffle and Sintered bronze and small amount of Steel Wool. I'll post back after 400 miles of High way commute on up hill drive. Average 2600RPM - 3100RPM showed in Torque
  17. Tekken
    Tekken Member
    260
    77
    Where did buy those Stainless Mesh ? I would like to try
  18. xliderider
    8,140
    3,278
    Honolulu, HI
    It's 80 mesh from Amazon:
    304 Stainless Steel Woven Wire 80 Mesh 0.18mm Hole - About 11.8 X 39.4 inch Roll(30cm X100cm)- Filter Screen Sheet Filtration Cloth Fine Wire Mesh
