Feature Suggestions | Bug Report - Share your ideas.
Discussion in 'PriiDash (TM)' started by 2009Prius, Jun 26, 2011.
  1. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    509
    63
    Feature Suggestions | Bug Report - Share your ideas.[FONT=&quot] (Visit the main thread and project home page if you haven't.)[/FONT]
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,994
    Fort Lee, NJ
    I have not gotten time to play with it today.
    Nomograph didn't seem to be working. The line was not straight when I tried it out yesterday.
  3. 2009Prius
    2,705
    509
    63
    I haven't looked at that for a long time. It updates quite slow so there will be moments when the line is not straight, but IIRC it should be straight most of the time. Here are some pictures from long time ago when I first did the nomograph:
    http://priuschat.com/forums/gen-ii-...un-early-problem-detection-2.html#post1224867
    Please let me know if it still doesn't work for you. Thanks!
  4. usbseawolf2000
    14,487
    2,994
    Fort Lee, NJ
    Ok, is it slow because you are getting other data all at once? If that's the case, is it possible to separate it into another page since MG1 and ICE rpm change quickly?
  5. 2009Prius
    2,705
    509
    63
    Yes and yes (but will take some time).
  6. 2009Prius
    2,705
    509
    63
    115200 baud for bluetooth test
    Attached. Test only. May not work.
  7. usbseawolf2000
    14,487
    2,994
    Fort Lee, NJ
    Thanks, will give it a try. We are still going through Irene and replanning our one week delayed vacation.
  8. ccdisce
    ccdisce Active Member
    259
    187
    Stone Mtn GA USA
    Re: 115200 baud for bluetooth test
    Ok I downloaded the file and it works with the laptop driving a Roving Networks RN-42 Bluetooth-UART connected to a SprakFun UART-OBDSol_STN11xx in the driveway and for a mile on the road when it goes into the familar lock-up mode.
    I think the problem is the chopped up packets caused by the slow (115200 bps) uplink speed. The documentation says that Bluetooth algorithms may chop up the data packet and cause problems further upstream.
    The intent this weekend is to set the Bluetooth speed higher to 1000000bps using the SZ command, change the Bluetooth algo latency using the SQ command and run the 1Mbps version of the PriiDash application.
    I may end up having to incorporate the changes that seem to be required by the USB Link method.
    w.
    2 people like this.
  9. SteveDH
    SteveDH Junior Member
    47
    London UK
    Add Command Line options
    Just wondering if it was possible to add command line support so that you could set the baud rate and enable/disable the debug log.
    just a though
    Steve
  10. 2009Prius
    2,705
    509
    63
    Yes those are on the to do list. Setting baud rate and other parameters are straightforward to code. The log files need more work.
  11. rhc3v6
    rhc3v6 Red Hat Certified Engineer V6
    Middletown, NJ 07748
    2003 Prius
    I
    Can I help with development of this for a GEN I Prius? I have a 2003 and could REALLY use this app! I have Linux laptops and desktops and am RHCE V6.
  12. 2009Prius
    2,705
    509
    63
    Sure go ahead. Just mark clearly all the changes you made. I am sure many gen 1 owners will be grateful for your effort. Thanks! :)
    For the GUI please use fluid to edit the dash.fl file and from there let fluid generate the dash.cxx and dash.h files. Thanks!
    If you could hold on for a few hours I will upload the most recent version tonight. Update: uploaded here:
    http://sourceforge.net/projects/priidash/
  13. nh7o
    nh7o Off grid since 1980
    1,686
    337
    Hawaii
    This is a great program and group. While I find it impressive as it is, and I want to say thanks again for all the work that has gone into it, my one comment is that the GUI is a bit more info rich than I can make use of while driving. In particular, I am most concerned with monitoring data that changes relatively slowly, mostly related to the temperatures of the main components, and the condition of the battery systems. Also, I do not use the GUI to read data that is already in the MFD or on the dash. Clearly some of the other details are useful to someone doing a hyper-miling research project, but I am more concerned with keeping things cool.
    With that in mind, I have put together a first pass at a simplified set of gauges. I hid the ones that seem optional (to me) and enlarged the ones that are of most interest so as to make a quick glance all that is needed to seem them on a small screen. I have attached a screen shot and the resulting file, call it priidash_lite.fld (get rid of the txt). I don't have the compilation software setup, so I am hoping that someone would be able to create a version using this file. I have been using the Windows executable in XP. This ought not change any of the logging functions, if I am not mistaken.
    Any comments or suggestions?
  14. 2009Prius
    2,705
    509
    63
    Thanks! I am away from home for a few days and will take a look when I get back. One thing I think of now is that if you have deleted some gauges then the compiler will complain. You need to find a way to hide but not delete the gauges that you don't need.
  15. nh7o
    1,686
    337
    Hawaii
    Ah so, I wasn't sure about what depended on what. I have updated the above priidash_lite.fld file to include all gauges, unchecking some of the attributes "Visible" and "Active", instead of deleting them.
  16. 2009Prius
    2,705
    509
    63
    It doesn't seem that you started from the most recent version of Dash.fl file (attached for your convenience). Could you redo it? Thanks!
  17. nh7o
    1,686
    337
    Hawaii
    No, I didn't look for releases....so here is priidash2_lite.fl. Engine specific at the top right, temp gauges bottom left, hybrid specific on the right. Any suggestions as for inclusions or further deletions?
  18. 2009Prius
    2,705
    509
    63
    OK it looks like I have made changes since last release but it's small enough change to merge. Attached is the CygWin binary. I only tested in simulation mode but it seems to work OK.
  19. nh7o
    1,686
    337
    Hawaii
    I still have not gotten CygWin going here, but will do so. It will take some time to download all that, due to my Internet connection. Perhaps someone could make another Windows executable, as with the previous version.
  20. 2009Prius
    2,705
    509
    63
    I just uploaded new version including Lite and Win32 exes at the project web site:
    PriiDash | Free Science & Engineering software downloads at SourceForge.net
    I only tested briefly. Somehow windows version still only gets ~ 1/2 of the CAN messages even though I turned on some optimization flags in VC2010. Sometimes the windows version loses COM port connection and I have to unplug and replug the USB cable.
    Give it a try.
