feedback while playing my iPod while being charged
Discussion in 'Gen 2 Prius Audio and Electronics' started by edisonjo, Aug 19, 2006.
  1. edisonjo
    edisonjo New Member
    I've tried multiple chargers to no avail! Whenever I play my iPod while it's being charged, I get all kinds of feedback (static, hissing sound, high pitched noise) ... not really loud, but just enough to make me not want to play my ipod. It works fine when it's not being charged. It's like the prius is sending too much electricity to the ipod and it can't handle it. Does anyone share this problem?
    I have a 2006 Prius (6 CD changer) with audio input in the middle console.
  2. LurkAzusa
    LurkAzusa Member
    231
    67
    Azusa, CA
    Do a search on Ground Loop isolator. You can find them at Radio Shack and Crutchfields.
  3. brandon
    brandon Member
    771
    Manhattan, KS
    Yep, agreed. Sounds like you're describing a ground loop, not feedback.
  4. zibudog
    zibudog New Member
    In them thar hills...
    <div class='quotetop'>QUOTE(brandon @ Aug 19 2006, 03:58 PM) [snapback]305986[/snapback]</div>
    Ground loop it is. Please post if you found an isolator and how it performed. I have that problem in my Sienna, and haven't used the cord with the Pod in the Prius yet.
    Cheers!
  5. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    I ran into the same problem and the one I mentioned at http://priuschat.com/index.php?showtopic=1...64&#entry228364 works great for me (except for having to have lots of different cables/adapters).
    It's not worth the money for me to buy yet another one w/the right wires.
    This needs to go in a FAQ somewhere!
  6. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    and just to clarify, the Prius doesn't "send" any electricity to the iPod, it's a pull system, not a push. Instead, the iPod draws what it needs from the cars system. So there is really no way to send "too much" electricity to the iPod... it gets exactly what it needs.
  7. edisonjo
    edisonjo New Member
    <div class='quotetop'>QUOTE(cwerdna @ Aug 21 2006, 12:52 AM) [snapback]306582[/snapback]</div>
    Yep ... seemed to work great (barring all the new cables that I shoved into the center storage unit). Clear audio. Thanks everyone for the feedback (no pun intended)!
