Feel bored by my Prius C, what should I add?
Discussion in 'Prius c Accessories and Modifications' started by zmarcoz, Nov 22, 2020.
Tags:
  1. zmarcoz
    zmarcoz Junior Member
    22
    I bought Prius C on 2013. It was a new car. In the past few years, I used 140K miles. I want to add something to make the car interesting again. Any suggestion?
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,790
    2017 Prius c
    ADD: A blonde in the passenger seat. :)
    Sounds to me like it's time to shop for a new car.
    If you live in the U.S., it is too bad that the C is no longer available.
  3. zmarcoz
    22
    However, I don't want to spend money on a new car.
  4. Leadfoot J. McCoalroller
    7,212
    6,774
    Pennsylvania
    2018 Prius c
    Put an aftermarket stereo in the dash- you can gain fancy carplay/android features, or just have better sound.
    The c is one of the easier transplant hosts out there, not a difficult DIY and that also keeps it cheaper if you pay somebody else to do it.
  5. orenji
    orenji Senior Member
    5,884
    3,486
    I had a Prius C and did a few modifications to make it mine own. I suggest you Google JDM Aqua and see what others have done.
    krmcg likes this.
  6. sam spade 2
    7,035
    2,790
    2017 Prius c
    Yea, I get that.
    Exciting......or cheap......take your choice.
    ANY money spent on "bling" will likely just be thrown down the drain.
    Even my flippant suggestion likely would cost you a LOT. :ROFLMAO:
    And consider that the age of your vehicle makes the odds fairly high that you have to start "spending money" on keeping it running in the fairly near future.
    A "newER" car might be an option. It doesn't have to be brand new.
  7. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    This is the Gen4 Forum - most here bought a Gen4 because ummm :sleep: ... we thought the Prius c boring.
    I'll request this be moved to the Prius c FORUM - you'll get better answers there.
    EDIT - nothing wrong with the "c" - it's more a budget city car than the all-rounder that the Gen4 is. Good for what it is.
    #7 alanclarkeau, Nov 22, 2020
  8. priusCpilot
    priusCpilot Active Member
    631
    209
    LA
    I recommend the Red bullet and the Injen intake with the Apexi throttler controller.
    My testing showed with the scan gauge back to back on the same road going both directions of knocking 0-60 down 1 second! I'm in the 9s now!!!! Throttle response was also much improved.
  9. AzusaPrius
    AzusaPrius Senior Member
    1,961
    846
    Yes the Red Bullet will put some pep in that prius.
    Go to redbullet.net
