Fender liner and front spoiler cover replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kopite88, Nov 29, 2019.
  1. kopite88
    kopite88 Junior Member
    North Carolina
    Hi all,
    The fender liner on the driver side of my Prius is missing and I'm planning on getting a new one installed. I ordered a non-OEM part since it's about a third the price. However, I noticed that the fender liner on the passenger side is also attached to the so-called "front wheel opening extension pad" (part number 53852-47020 for driver side, see picture on the left). What is the purpose of this part and will I need to install it to the fender liner as well?
    Also, the front spoiler cover (76851-47030) is looking pretty beat up, currently held up by a zip tie (see picture on the right). Is this something that I need to replace as well?
    My mechanics quoted almost $550 for both to be fixed (>$350 for parts), which I thought to be too expensive. I've never done much car repair myself but thought I should give this a try. I've found a few relevant threads on the forum with useful information but any other suggestion would be much appreciated!
  2. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    My guess is that, despite the drain hole, Toyota figured too much water (maybe salt, too) was entering through that part of the floor pan. Otherwise, and unless you need it to help anchor the fender liner, the extension pad seems optional.
    kopite88 likes this.
  3. Mendel Leisk
    41,879
    The wheel well liner, and the spat at the bottom edge, and plastic ahead of it, you might as well treat as a single piece. I think Toyota actuall does. There's 3 bolts going through the spat, that clamp together the front piece and wheel well piece. On the inside there's a piece of flat bar and square weld nuts, for the 3 bolts. At least in my locale, those 3 bolts and the weld nuts were in a rusty marriage that's impossible to undo. Also, at the rear of the wheel well there's a screwing going into a plastic insert, that I think you pretty much have to destroy to remove. Oh, and on the side of the wheel well, around 2 oclock as you're facing the passenger side wheel well, there's a fastner with a slot in the cap: that cap needs to be turned 90 degrees to release.
    The front piece with the zip tie, just track down the missing fastener, for starters. That said, that piece tends to take a beating from concrete wheel stops. It's low, and the engineers in their brilliance designed it like a barbed hook: the piece rides up and over the concrete curb stop before the wheels contact it, with a great scraaaape. Then when you back out the aforementioned brilliant design snags royally, tears itself half apart. Long story short, you may need to mend some fracturers at the lower edge: fiberglass mesh and 2-part epoxy on the inside is pretty good for that.
    Robert Holt and kopite88 like this.
  4. kopite88
    North Carolina
    Thank you!
    Since the whole piece is missing, I'm just gonna try to install the fender liner without that bottom extension pad for now. There's a good chance that the non-OEM replacement part that I ordered doesn't even have the holes to attach to the pad anyway. Seems like it's not a critical part.
    As for the front spoiler cover, I'll need to reassess its condition before deciding on whether to repair or replace it. I'm new to a lot of this stuff so I'll need to keep it simple at first. Thanks for your helpful suggestions though!
  5. Mendel Leisk
    41,879
    The front spoiler is easily removable, without even raising the car: one row of bolts (screwing into weld nuts), one row of coarse-thread screws (screwing into nylon blocks locked into the front fairing), and a single odd-ball shaped plastic fastener in the middle. The row of bolts holds the leading edge of the engine underpanel as well.
